![]() | Home > Maintenance & Modifications > Diff pinion seals |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8203 ![]() ![]() ![]() |
If it has a fair few miles on it And the breather is not blocked then I would do flange and seal. If breather is found to be blocked just do seal. If flame comes out unsecured then you may get away with just a seal. Impact gun is beneficial for this job. Cheers
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 ![]() ![]() ![]() |
I replaced seals only, sanded down flange seal area but they still leaked.
I then bought a kit flange n seal and all has been well since. So my 2p is to be done with it properly, buy the kit |
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 ![]() ![]() |
This may help
https://www.lrworkshop.com/axles-different...-oil-seals |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 808 ![]() ![]() |
Thanks for the replies. I have identified the correct seal and have decided to change just the seals and see how it goes. BORG - Bucks & Oxon 4x4 Response Group
