Home > Puma (Tdci) > On ignition temp gauge goes max and engine will not start. |
have read link below
On ignition temp gauge goes max and engine will not start. form LR https://1drv.ms/b/s!AtZSoWFHDgnGkWWX3oCmmZLsQs5-?e=iHwOzU |
23rd Dec 2019 4:20pm |
pcoote Member Since: 01 Aug 2010 Location: Oxford Posts: 83 |
Thanks dorsetsmith that sounds spot on. I will check the fault codes tomorrow.
23rd Dec 2019 4:49pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6604 |
Gauge in the max can mean that the ECU isn’t running - either a crashed ECU as in the LR bulletin, or look at the fuses supplying it.
What year is your Puma? 1988 90 Td5 NAS soft top 2015 D90 XS SW |
23rd Dec 2019 6:19pm |
Sorry can see it’s a 2010 1988 90 Td5 NAS soft top
2015 D90 XS SW |
23rd Dec 2019 6:23pm |
Hi Martin,
My ECU has the code 0G182 which according to the service bulletin translates to a manufactring date of 1st July 2010. So that means it's after the bad batch which were before 14th October 2009. I noticed when I flashed the Alive tuning back to the original the temp gauge went into the red during the flash and then went back to normal after completing. So as you say this indicates the original problem was ECU related. I have 4 DTC fault codes 2 which look related to ECU P0606 (Control Module Processor), P068A (ECM/PCM Power Relay De-Energized - Too Early). I did notice when putting the battery in the second time after the breakdown the battery terminals were dry so I smeared on petroleum jelly. Anyway I have not had a repeat incident so far. I'm driving it to the Alps in a few weeks so I'm now feeling nervous. |
28th Dec 2019 3:08pm |
Fabio Member Since: 05 Aug 2011 Location: Somerset Posts: 589 |
I had this happen to mine yesterday.
Under the drivers seat there is a few relays , If you unplug the second from last towards the back and clean it, it will be fine. I did buy cleaner and cleaned it as well. It is fine now. Fabio |
28th Dec 2019 6:29pm |
PDX-VTE Member Since: 28 Jun 2018 Location: Laos Posts: 1 |
My 2010 had the same symptoms (temp gauge max out and no start) and it would eventually start after a few tries. It would takes more and more tries before the glow plug light comes on, until about a month ago the ECU completely gave up. I had the ECU replaced with a NNN501630, like in the service bulletin, and it starts right up, temp gauge doesn’t go to max and glow plug light comes on like it should. My VIN number was after the supposedly affected vehicles, and so was the production date on the bad ECU, it was after the “bad batch.” I am in Laos and parts are spendy, that is why I was reluctant to replace the ECU over a year ago when I first bought the vehicle. But after a year of not starting right away and starting immediately, I wish I would have replaced it sooner.
15th Jan 2020 10:03am |
Steve maman Member Since: 17 Feb 2021 Location: Montreal canada Posts: 4 |
Hi , can you share the file ? I have the exact issue and am lost with no ideas left !
25th Jun 2024 2:52am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2412 |
https://gershon.ucoz.com/landrover/PUMA/Se...ture_G.pdf Puma 110" SW
25th Jun 2024 1:12pm |
