![]() | Home > Puma (Tdci) > Drone/Vibration between 1600-2000rpm |
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 ![]() ![]() ![]() |
Hi, sadly not. I tend to drive outside of that rev range where possible and is something I just got used to.
Sorry that's not much help! Have you checked the usual suspects such as the turbo heatshield? Regards... Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
Dave H Member Since: 18 Aug 2013 Location: Bexley Posts: 28 ![]() ![]() ![]() |
Thanks for the quick response, the vibration seems to run the length of the vehicle so not the heat shield. I’ve had her for around 4 years now and this has been going on for around a year. Checked all the normal stuff. I could run it into a garage but guess they would run up a hefty bill just looking for the problem.
I will keep looking and let you know if I find anything! Thanks again. |
DG123 Member Since: 29 Aug 2015 Location: North West Posts: 136 ![]() ![]() ![]() |
I had a similar drone - it got so annoying I had to travel below 50 or over 70, or cruise in 5th to keep the revs up
![]() I finally got round to changing the original Conti Cross Contacts after about 60,000 miles and replaced with BFG KO2’s. I had the wheel alignment done at the same time as there was some strange wear patterns on the front tyres. Drove back home on the motorway - silence ![]() ![]() 2003 D2 Td5 Black [SOLD] |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20718 ![]() ![]() |
I believe Blackwolf on here had similar sort of issues as you had with tyre wear before.
On alternate tread blocks if I remember rightly. Another vibration culprit can be a hidden UJ failure on the prop shafts. It only takes one, often the rear most is the culprit. They can seem fine in situ, with all manner of prying and checking but you can only tell if the are really in good order by removing and articulating fully. It took me months to did out where I had this, and in the process had a diff leak created multiple times. So if you ever get a pinion oil leak, check the UJ’s in depth nearest to it. You might find that’s the culprit too, and if not repaired you’ll get the oil leak back over and over. Even the Indi I use missed the failed UJ cup and seized bearings on mine and the MOT tester. Been awesome since with the GKN ones. It would have been interesting with the tyres you had issues with if they still did have problems if you added Dynabeads in. Or did you already use those too? If you didn’t and still have them around it maybe interesting to give it a go perhaps? WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
orzowei Member Since: 10 Mar 2021 Location: toscana Posts: 14 ![]() ![]() ![]() |
Anche io ho lo stesso rumore a 1400 giri. Ho cambiato il map e ho tagliato lo scarico sostituendo il soffietto di lamiera con una rete. Ma niente la vibrazione e' rimasta. Onestamente mi son arreso. I also have the same vibration noise at 1400 rpm. I changed the map and cut the exhaust system by replacing the sheet metal bellows with mesh manifold. But nothing the vibration is still there .. Honestly I give up ... sorry for the translation ---- |
