Home > Puma (Tdci) > Oil leak - Rocker Gasket??
Atters
Help Please! 2011 Defender 90 Pickup 2.4 TDCI. 33,000 miles. Engine picture and picture of oil leak just under exhaust manifold.
Leak seems to come from just below fuel injector manifold and above exhaust manifold. Then it leaks all the way down and drips off bottom of oil filter and sump. Only leaks when running. i.e. does not drip on to driveway when standing. Other side of engine totally clean no leak at all. My hunch is rocker gasket leak, but would really like some wisdom from the forum is whether this makes sense? Is it a known issue? hard to fix?
Thanks to all.
Post #612355 26th Mar 2017 8:23pm
FinnSmith
United Kingdom 2009 Defender 90 Puma 2.4 SW Corris Grey
Hi, I have the same issue? just wondering if you found the cause to the issue? cheers
Post #804578 3rd Dec 2019 12:03pm
fatboyron
Yes I have the same problem any news on what is causing this and how to fix it
Post #806690 17th Dec 2019 9:42pm
Argee
I had this but with equivalent leak at the intercooler hose on the drivers side as well.
Turned out to be the turbo oil seal, so new turbo. Upgraded the intercooler for the big BAS one at the same time and then treated it to a stage 2 remap.
Every silver lining and all that....
Post #806752 18th Dec 2019 12:44pm
FinnSmith
My car went into a landrover specialist on Tuesday for the repair. He reckons it was injector seals pressurising the rocker cover gasket. Try taking the oil filler cap off and check to see if there’s a lot of pressure and a chugging sound. That’s what I was recommended to do. The repair was around £300. Seems to have stopped the leaking so far.
Post #806821 18th Dec 2019 10:08pm
fatboyron
Thank you both for your replies yeah I'm going to take mine in tomorrow and I mentioned to see if that is the injector seal and I'll post my findings
Post #806899 19th Dec 2019 3:46pm
Gloucesternige
United Kingdom 2011 Defender 90 Puma 2.4 HT Keswick Green
If anyone is looking to buy new injector seals I found the best supplier to be MM4x4 nr Droitwich. They supplied me with four off for less than £20, made by Elring. Other places charge £11 each for them!!
Nige
Post #810716 17th Jan 2020 2:14pm
