Home > Puma (Tdci) > Oil leak - Rocker Gasket?? |
FinnSmith Member Since: 03 Dec 2019 Location: cheshire Posts: 4 |
Hi, I have the same issue? just wondering if you found the cause to the issue? cheers
3rd Dec 2019 12:03pm |
fatboyron Member Since: 28 Jul 2018 Location: Aylesham Canterbury Kent Posts: 116 |
Yes I have the same problem any news on what is causing this and how to fix it
17th Dec 2019 9:42pm |
Argee Member Since: 13 Nov 2017 Location: Suffolk Posts: 71 |
I had this but with equivalent leak at the intercooler hose on the drivers side as well.
Turned out to be the turbo oil seal, so new turbo. Upgraded the intercooler for the big BAS one at the same time and then treated it to a stage 2 remap. Every silver lining and all that.... |
18th Dec 2019 12:44pm |
My car went into a landrover specialist on Tuesday for the repair. He reckons it was injector seals pressurising the rocker cover gasket. Try taking the oil filler cap off and check to see if there’s a lot of pressure and a chugging sound. That’s what I was recommended to do. The repair was around £300. Seems to have stopped the leaking so far. |
18th Dec 2019 10:08pm |
Thank you both for your replies yeah I'm going to take mine in tomorrow and I mentioned to see if that is the injector seal and I'll post my findings
19th Dec 2019 3:46pm |
Gloucesternige Member Since: 17 Jan 2020 Location: In the garage Posts: 114 |
If anyone is looking to buy new injector seals I found the best supplier to be MM4x4 nr Droitwich. They supplied me with four off for less than £20, made by Elring. Other places charge £11 each for them!!
Nige |
17th Jan 2020 2:14pm |
