Home > Puma (Tdci) > One wiper not working |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 744 |
Just had similar with my drivers wiper.
Dashboard had to come out to find the gear was stripped in the wiper gearbox. Best to change both gearboxes and flexi drive while you’re in there, and possibly the park switch. |
18th Dec 2019 6:01pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3310 |
. I feared as much. WARNING.
This post may contain sarcasm. |
18th Dec 2019 6:06pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20437 |
You could try lubing down the spindle for the time being, it could be binding due to corrosion and adding to it.
Beyond that though, it'll be wiper wheel boxes out and drive. You'd need new wiper arms and likely a puller too as well, as the wiper arms are a press fit on a splined spindle on the Puma. At least, most of the parts are worth replacing at once is advisable. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 Last edited by custom90 on 18th Dec 2019 7:05pm. Edited 1 time in total |
18th Dec 2019 6:20pm |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1218 |
Zed...
you will have only used one third of the teeth on your wiper boxes. Mark the position before you take apart. Rotate through 180 degrees and you are on new teeth. I did this a month back and all is/was good. ( I renewed the drive cable too) Hope this helps Clemmo Make today a little better than yesterday but not so good as tomorrow.... Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadster……..........Vermillion 17k miles Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun Last edited by Clemmo on 19th Dec 2019 9:41pm. Edited 1 time in total |
18th Dec 2019 6:32pm |
Why do you need new wiper arms?
I’ve removed puma wiper arms several times without a puller and refitted them. |
18th Dec 2019 6:52pm |
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 |
Hi,
I also have a problem with it. Is there info to how take the dashbord of ? Thanks Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
19th Dec 2019 5:07pm |
You don’t have to remove the Dashboard....purely loosen it.
Get the smaller screws below knee level..both sides. Then undo the bigger Phillips type screws, including the grab handle and the radio/centre console. I’ve found rather than struggle.... take the steering wheel off, remove the light/indicator Plastic supports and release the instrument panel too. The more you loosen the easier it becomes. It’s a fiddle..but not difficult Clemmo Make today a little better than yesterday but not so good as tomorrow.... Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadster……..........Vermillion 17k miles Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun |
19th Dec 2019 6:05pm |
driver Member Since: 02 Aug 2009 Location: bude , cornwall Posts: 206 |
Just done this job on mine, here are a few pics of whats needed basically you have to get it back to the bulkhead to get to the wiper boxes,
Didn't remove dash completely but moved it well out of the way, you will also need to remove all the heater pipes as well, I removed the wiper motor, drive cable and two spindles as a unit then stripped, cleaned everything. It took me a whole day to complete this including taking loads of pics for reference.[/code] Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
19th Dec 2019 7:14pm |
Great pics there. $W33T $0U7H3RN $UG4R
19th Dec 2019 7:19pm |
Thanks
19th Dec 2019 7:21pm |
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Here is a couple more, I used these for reference for cable routing. |
19th Dec 2019 7:27pm |
Thanks for all the replies gentlemen. I will give it a go in between eating mince pies. WARNING.
21st Dec 2019 12:50pm |
