![]() | Home > Puma (Tdci) > Belt pulleys play/noise clicking |
Snorkers Member Since: 10 Oct 2015 Location: Grampian Posts: 34 ![]() ![]() ![]() |
Hi there. I too had a horrendous noise on my 2.4 which was driving me mad. I traced it to the alternator drive pulley. It is designed to drive in one direction and spin freely in the other. Mine started to fail which caused it to clunk loudly which was most audible when shutting off the engine. These pulleys. Can be replaced but you need a special tool which runs about £30 from tool makers such as Laser. The pulley can be bought from a motor factor for about £35 and its likely listed for a Ford Transit. I don't have the part numbers to hand but did post them previously. A search should find them. Please don't swap out the entire alternator for the sake of the pulley 😀
I'm not saying that this will be the cure for all your noises but the alternator pulley shouldn't make any rattling or club's when in use. Hopefully someone will chip in with more opinions / help. Regards as always. Snorkers |
