Home > Maintenance & Modifications > Replacement horn / TD5
Enid_Puceflange
Scotland 2002 Defender 110 Td5 DCPU Baltic Blue
Hi folks
After a little bit of wading, my horn has pretty much packed in and been reduced to a whimper
Are all horns just a simple case of connecting the wiring and off you go?
I need to replace mine before it’s next MOT in April , and would like something MEGA!!
You know, like a train horn Thumbs Up
Any suggestions
Image below of my dcpu being used to recover vehicles stuck in floods during the summer Cool
( the day my horn packed in )
 My confidence has been writing cheques that my abilities can't cash for years.
Post #805366 8th Dec 2019 6:24pm
markb110
Hi Enid
You could go for an air horn, what I did was to buy two uprated horns, replaced the original in the standard position then added the second one to the opposite wing (behind the grill in the headlight surround) then ran a wire to link them together.
Works pretty well for me and much better than the single original squeaky version.
Good luck
Post #805401 8th Dec 2019 9:50pm
PIAA dual horns.
Post #805402 8th Dec 2019 10:12pm
rallysteve
Air horns dont fare well in the water if you are thinking of dunking it further.
I agree with the PIAA twin horns Thumbs Up .
Post #805429 9th Dec 2019 9:27am
markb110 wrote:
Hi Enid
Good luck
I thought that a Td5 was like a Puma and had twin horns from the factory.
Post #805438 9th Dec 2019 10:36am
grafty99
Only county spec and up had twin horns I believe. My 90 was base spec from the factory and only had 1. Has 4 now though Rolling with laughter 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #805440 9th Dec 2019 11:02am
rallysteve
My 02' DCPU only had a single horn fitted from the factory too.
I used the second horn connection as the trigger for a relay for my loud aftermarket horn. I have also fitted another relay which prevents the aftermarket horn sounding unless the ignition is on so as to keep down the neighbour annoyance when the alarm goes off!
Post #805443 9th Dec 2019 11:22am
My '07 Puma County spec DCPU had 2 fitted but only 1 worked, a sort of half way house between the poverty spec single horn and the top spec twin, perhaps! Rolling with laughter
Post #805515 9th Dec 2019 7:26pm
Zed
My 2010 XS had 2 fitted but only one was connected. WARNING.
Post #805526 9th Dec 2019 7:52pm
ppad
United Kingdom 2005 Defender 90 Td5 HT Caledonian Blue
My 05 base van style 90 again only 1 horn, LHS near grille. Installing twin airs made the appropriate truck noise Very Happy
but did need a relay according to the install kit so you'll need to choose appropriate location for wiring. In the end I chose tucked away under the bonnet on inner wing. Sold the much modified 110 2.8, in Oz
Brought the 90 home from Switzerland ...
Post #805563 9th Dec 2019 10:36pm
