Home > Puma (Tdci) > 2.4 will not start
Zixxer
Ireland 2009 Defender 110 Puma 2.4 HT Keswick Green
2.4 will not start
Hello lads my 2.4 will not start
She is basic spec with no key fobs or central locking
The problem came out of the blue - just very difficult to start suddenly
Got her going last night with some easy start and she performs perfectly once she starts.
However today even easy start failed to work - after letting the glow plugs cycle complete she almost fires up and then try again immediately after there is nothing.
If you leave her sit for a few minutes and try again the same result - almost fires and then cranks over endlessly after.
New battery too - please help any assistance would be great
Post #804760 4th Dec 2019 7:15pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Are you getting fuel to the infectors.? Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #804817 5th Dec 2019 9:34am
Zixxer
I tried to check that by disconnecting the little pipe that feeds the rail at the back towards the bulkhead and am only getting a little dribble of diesel when cranking her over
Post #804820 5th Dec 2019 10:23am
Zixxer
This is the pipe I’m referring to - when turning her over only a dribble comes from it
Post #804824 5th Dec 2019 10:32am
Zixxer
Trying to upload a pic but for some reason it’s not working - it’s the pipe at the back of the common rail
Post #804825 5th Dec 2019 10:33am
dorsetsmith
this may help
Post #804829 5th Dec 2019 10:51am
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Fuel filter blocked? ....fuel pump not working?
Post #804840 5th Dec 2019 11:49am
dorsetsmith
number 1 on lower pic high presser feed from pump to common rail Question
Post #804846 5th Dec 2019 12:26pm
Zixxer
Diesel system looks fine getting plenty at the rail
Getting a P068A fault code and have checked all the relays under the seat a dozen times
Going to try cleaning crank sensor now see if it’s stopping her running
Post #804869 5th Dec 2019 4:31pm
dorsetsmith
Getting a P068A fault code have read below
https://www.defender2.net/forum/topic18700.html?view=next
Post #804871 5th Dec 2019 4:37pm
Zixxer
Took out crank sensor tonight and cleaned it - wasn’t really dirty anyway, made no difference
When the computer was connected today the live data showed she would turn over at around 600rpm sometimes and nearly get running and if you try and start her again immediately after it only barely reaches 300.
Leading me to believe the crank sensor might be faulty so I’m going to try put a new one in tomorrow
I’m not sure how exactly you know the correct depth to insert the new sensor, but will try a new one to see if it makes any difference.
Post #804890 5th Dec 2019 7:31pm
dorsetsmith
you have two sensor one crank sensor and one camshaft position sensor
Post #804901 5th Dec 2019 8:18pm
Zixxer
Yes I plan to change both tomorrow if I can get my hands on them
I will report back how I get on afterward
Thanks for the help
Post #804904 5th Dec 2019 8:35pm
Zixxer
Crank sensor part number 6740819
Cam sensor part number 1358343
Both will be replaced tomorrow as they are reasonably small cost and easy replacement
In the meantime I gave the ignition wiring a check to make sure nothing is loose
I would have liked to get into the ecu mounted on the bulkhead inside the engine bay just to clean and check the connections but it looks caged inside some sort of box with shear bolts
If changing the two sensors doesn’t do anything that’s where I’m headed next
Post #804906 5th Dec 2019 8:40pm
Zixxer
She’s alive again!
Cam shaft sensor - easy to get at, cheap replace and stopped my 2.4 dead
Hope this thread is useful to someone in future - I was at my wits end with this, so if you find this thread don’t give up, you’ll get it
Post #805001 6th Dec 2019 4:08pm
