![]() | Home > Puma (Tdci) > 2.4 will not start |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
![]() So the culprit was the Cam Shaft Sensor ![]() and you also replaced the Crank Sensor ![]() Maybe worth carrying these two if out 'in the field' What was the cause of the fault code P068A ![]() Do you have a 'gauge' connected to your OBDII socket ![]() Thanks SKIP https://www.defender2.net/forum/topic83242.html |
Zixxer Member Since: 04 Dec 2019 Location: Tipperary Posts: 17 ![]() ![]() ![]() |
Absolutely - if I ever go on another long adventure I’m bringing spare sensors
