![]() | Home > Td5 > TD5 Dash Ashtray Mod |
JSaxton Member Since: 16 Dec 2017 Location: Nottinghamshire Posts: 27 ![]() ![]() |
Check out DeftCAD I bought his phone holder and is brilliant!
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5868 ![]() ![]() |
Mines fitted with the coin/trinket tray as it’s a late model. Much more useful than the ashtray.
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4801 ![]() ![]() ![]() |
I've 3D printed myself a garmin ball and arm, which replaces the ashtray and accepts the garmin satnav mount
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
![]() Click image to enlarge Ta da! 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4801 ![]() ![]() ![]() |
![]() 2008 SVX 90 2000 XS TD5 90 |
ashfordsv Member Since: 13 Mar 2009 Location: Wicklow Posts: 82 ![]() ![]() ![]() |
Very neat
![]() Mud also have a good solution https://www.mudstuff.co.uk/coin-holder.html |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 436 ![]() ![]() ![]() |
Take out the metal strip in the ash tray - it leaves a good coin area with a lid so the coins are not visible
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 968 ![]() ![]() ![]() |
Centre channel speaker.
![]() Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6163 ![]() ![]() ![]() |
+1... removed my ashtray (I had hacked it about anyway as used to have my GPS3 mounted on it) but now have the coin tray. Can fit a kenwood 2way radio in it which stays in place during most laning trips. falls out if you bounce around a bit though. |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1369 ![]() ![]() |
i use it for keeping screws safe for when you start a job, but can't finish it as you need a part.
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 723 ![]() ![]() ![]() |
I have the Mud coin tray and happy with it, it holds more junk than the ash tray did. The only minor complaint is that it doesn't sit flush with the dash, it sits about 4mm proud due to the springs.
A 3D printed jobby the holds my phone, allowing it to be used as a sat nav whilst charging is on the wishlist ![]() 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
I've adapted my ashtray into a compass mount:
Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1179 ![]() ![]() ![]() |
Some cool stuff mentioned lads
Keep em comin ![]() |
Got to tidy mine up a bit but I cut a piece of ply to fit the hole, painted it black, then it fixes to a strip of steel under the crash pad to keep it in place. On this is fixed my digital 2 way radio that is set up for Zello for communications with my local 4x4 Response Group.
