Home > Td5 > Rotor filter housing thread stripped
Andy T
United Kingdom 2011 Defender 110 Puma 2.4 SW Fuji White
Don't you just love it when a 'routine' saturday afternoon job takes your Landy off the road? Crying or Very sad
Having smugly removed the TD5's oil filter without much trouble, the 2 bolts on the rotor filter housing seemed a cinch - until one of them did a great impression of a spinning top Big Cry
So cramped that I needed the Dremel to cut it off
Now waiting for an M6 helicoil kit to be delivered, though somewhat scared as I've never used one - is threadlocker a good idea with it?
Anyone else had this issue? Pearls of wisdom welcome please Bow down 2011 2.4 White 110 CSW LHD
1998 300TDi Wolf TUM
2015 2.2 Corris Grey 90
2009 2.4 Alaska White 110 Commercial - gone
2006 TD5 Barolo Black 90 - gone
1995 TD5 Green 90 - gone
1984 2.25 Marine Blue 88
Post #804335 1st Dec 2019 6:45pm
Ive seen the hole drilled straight through and a nut n bolt do the job.
Post #804337 1st Dec 2019 6:47pm
Andy T
Cheers, may come to that if the Helicoil fix goes badly! Wink 2011 2.4 White 110 CSW LHD
Post #804338 1st Dec 2019 6:53pm
bankz5152
Common issue. Mines nut and bolted. Right pain but works. Ive got a new housing to.fit just havnt got round to it Instagram @defender_ventures
Empire Tuning - Agent
Post #804339 1st Dec 2019 7:11pm
Very easy to helicoil, and a very common problem. Don't use threadlock with helicoils.
Post #804343 1st Dec 2019 7:30pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
How many td5’s don’t have a nut and bolt? I know mine has.
I thought of a helicoil but it looks as though the housing will have to come off to get good access, so I haven’t bothered.
Easier to get the nut on before you fit the screw on filter!
Post #804347 1st Dec 2019 7:54pm
rallysteve
Helicoiled both mine first time i serviced it. Did it in situe and taped over the filter hole to keep any swarf out whilst i did it. 02' 110 TD5 Double Cab Rebuild Thread
Post #804354 1st Dec 2019 8:20pm
fidocrew
United Kingdom 1998 Defender 90 300 Tdi CSW Epsom Green
nut and bolt every time!!
Post #804386 1st Dec 2019 11:02pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Fitting a Helicoil is easy if you have the correct drill, tap and insertion tool.
The last time I fitted one (IIRC it was a 2" whitworth ) I was 200 foot up a distillation tower in freezing weather. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #804402 2nd Dec 2019 7:56am
dorsetsmith
in aluminium with pre drill hole tap and insertion tool. all will need and Helicon insert
Post #804411 2nd Dec 2019 9:26am
TJH1985
Nut and bolt here Mr. Green
Post #804412 2nd Dec 2019 9:37am
excossack
and here! 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #804416 2nd Dec 2019 10:11am
The only minor issue with the extremely popular nut and bolt solution is that the lower face of the casting, against which the nut will sit, is not perpendicular to the hole, so the nut doesn't sit flat.
This doesn't stop the fix working, but can offend one's engineering principles especially if one is prone to OCD. Sad
In this case, a Helicoil or Timesert threaded insert is the only solution that will allow a good night's sleep. Thumbs Up
Post #804418 2nd Dec 2019 10:23am
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Probably a bit late, but I would highly recommend Wurth time serts,
Used in Motorsport as std bu many quality manufacturers 👍
Post #804487 2nd Dec 2019 6:40pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
I just tapped a new thread into the old stripped hole. I also wrap the threads on the bolt with Teflon plumbers tape and it helps isolate and prevent the problem from happening.
Nut and bolt are a simple fix, if a bit fiddley when you do change the filter. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #804514 2nd Dec 2019 7:58pm
