Home > Maintenance & Modifications > Weird Electrical Issue |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2222 |
Check the earth at the back door. The high level brake light and heated rear window share and earth path. If that is damaged it is probably earthing back through the brake lights.
I would possibly even put money on the earth cable being broken in the rubber convoluted tube that runs to the rear door. Steve 02' 110 TD5 Double Cab Rebuild Thread |
26th Nov 2019 9:34pm |
llessur Member Since: 15 Nov 2011 Location: Hereford Posts: 151 |
Steve,
Thank you , I will make that my first check point. |
26th Nov 2019 9:39pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1027 |
That's actually a feature to scare the tailgater behind you |
28th Nov 2019 7:54pm |
I wish I had a pound for every time a car comes up so close that their headlights disappear from view.( I probably should not admit it but I was taught (by a Police Class 1 instructor ) to take my foot off the accelerator and quickly put it back on, to "wake" the tail gater up. It works a treat, and they normally drop back and keep their distance
Not had chance to look at the electrical gremlin yet, but I will report back when sorted. |
28th Nov 2019 8:08pm |
Yes, you were absolutely correct. The earth connection between the rear door and the vehicle had failed, wire replaced and all is now as it should be.
Thanks |
29th Nov 2019 4:49pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3651 |
Glad it’s sorted. Your 90 looks great, let’s see a few more full size pics!
29th Nov 2019 8:10pm |
Glad it was an easy fix! 02' 110 TD5 Double Cab Rebuild Thread
30th Nov 2019 10:43am |
