Home > For Sale & Wanted > [Wanted] 110/P38 rear diff
Anyone got a 110 or P38 rear diff for sale? doesn't matter if it's 2 or 4 pinion as it's going to have an Ashcroft locker glued into it.
Would prefer a rear from a P38, as opposed to a front, eventhough they're the same, as the teeth run backwards on the front one; Dave @ Ashcrofts recommended to me to try and use a rear if possible.
Cheers all Bow down
Post #799790 28th Oct 2019 2:19pm
Post #803225 22nd Nov 2019 7:33pm
Re: [Wanted] 110/P38 rear diff
diesel_jim wrote:
... doesn't matter if it's 2 or 4 pinion ...
[Engineering pedant mode on]
I think you'll find that they all have only one pinion.
You may find either two or four differential (or spider) gears though!
Post #803230 22nd Nov 2019 8:01pm
Pedant mode accepted and appreciated Cool
Post #803231 22nd Nov 2019 8:02pm
Mdm
i have one in the shed somewhere removed from a 110 puma back end circa 76k but noisy bearing.not needed it yet for the new puma so was thinking of throwing a locker in it and rebuilding to minimise time of the road but happy to sell it.
Post #803286 23rd Nov 2019 11:04am
How much for? and where are you?
cheers
Post #803370 24th Nov 2019 8:16am
Mdm
try these ill pm location
Post #803384 24th Nov 2019 9:57am
jst
Jamie, does Dave have any low pinion hypoid P38 stude hole lockers left? stronger than std pinion/crownwheel Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #803394 24th Nov 2019 1:46pm
I don't know, not asked. I've not managed to break a standard diff yet, so with the bimbling around I do at the moment, I think it would be a wasted expense to go for the hypoid one.
Post #803436 24th Nov 2019 8:39pm
jst
Mdm will be good when buy from him have bought pleny off him before and no problems. If your not in a rush will see him. Feb time. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #803499 25th Nov 2019 4:13pm
