![]() | Home > For Sale & Wanted > [Wanted] 110/P38 rear diff |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
[Engineering pedant mode on] I think you'll find that they all have only one pinion. You may find either two or four differential (or spider) gears though! |
Pedant mode accepted and appreciated
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1636 ![]() ![]() |
i have one in the shed somewhere removed from a 110 puma back end circa 76k but noisy bearing.not needed it yet for the new puma so was thinking of throwing a locker in it and rebuilding to minimise time of the road but happy to sell it.
How much for? and where are you?
cheers |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge try these ill pm location |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8166 ![]() ![]() ![]() |
Jamie, does Dave have any low pinion hypoid P38 stude hole lockers left? stronger than std pinion/crownwheel Cheers
I don't know, not asked. I've not managed to break a standard diff yet, so with the bimbling around I do at the moment, I think it would be a wasted expense to go for the hypoid one.
Mdm will be good when buy from him have bought pleny off him before and no problems. If your not in a rush will see him. Feb time. Cheers
