Home > Maintenance & Modifications > Ball Bearing Security |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
I use metal putty pushed into mine.
21st Nov 2019 11:16am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2235 |
I'm lucky enough to not have the attractive kind of door 😇
21st Nov 2019 1:20pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 666 |
Maybe some stick on rust patches is the answer?!
21st Nov 2019 1:42pm |
No, stick on square corners and window winders 😂
21st Nov 2019 2:10pm |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
I bought those a while back and found that they're not much use on the Nakatanenga stainless bolts because they don't stay put in the Torx hole. They can be bonded in place but even then they protrude and can easily be extracted using a screwdriver/chisel + hammer. The vendor indicated that he'd recently experienced the same on his son's vehicle and offered a complete refund. |
21st Nov 2019 3:39pm |
TheShrink Member Since: 25 Apr 2019 Location: Somerset Posts: 47 |
If using silicone, is there any specific silicone that people would recommend?
Thanks |
22nd Nov 2019 9:33am |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 400 |
--- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
22nd Nov 2019 9:40am |
lakelander Member Since: 07 Jan 2017 Location: Cumbria Posts: 100 |
have got these inserts in each of the top hinges on the A post, and they have been hammered well in . Has anybody succeeded in removing and how did you go about it. I want to replace all the bolts with SS and am tempted to just leave these in place as the insert shows no rust and as the vehicle is Orkney Grey they blend in quite well.
any thoughts? |
22nd Jun 2020 2:06pm |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 937 |
^^^ Anyone asking how to defeat security measures will be unlikely to get much information provided. Whilst it might be frustrating, it is also very reassuring when you think about it.
22nd Jun 2020 3:07pm |
thanks for reply. Yes i understand - but these inserts are a deterrent to make an opportunist think twice as whatever method you use it will be time consuming. They seem to be a simple, cheaper and unobtrusive way to help you keep ypur doors. Have decided to leave them as they are
22nd Jun 2020 3:19pm |
