Home > Tdi > 110 CSW chassis/body mounting bracket |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2314 |
Not seeing a picture? > 110 XS Double Cab
19th Nov 2019 12:53pm |
Walty84 Member Since: 24 Feb 2018 Location: Ireland Posts: 10 |
Sorry, was uploading from phone....Should be visible now.
19th Nov 2019 1:07pm |
Yes showing now. What year?
Do either of these help? https://www.lrworkshop.com/diagrams/land-r...ings_52776 https://www.lrworkshop.com/diagrams/land-r...ings_44902 > 110 XS Double Cab |
19th Nov 2019 1:16pm |
Sorry should have said 1998 300tdi
Thanks for the links, they were actually the ones I was using for reference, however nothing there seems to marry up with mine? Im now wondering is it a body part as opposed to a chassis part.... |
19th Nov 2019 2:20pm |
Click image to enlarge Found this image online. Might show the bracket a bit better, bolt pattern circled. ?? |
19th Nov 2019 3:19pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 672 |
Is this it?
https://yrmit.co.uk/product/110-mid-crossm...-defender/ Edited: With these brackets too? https://yrmit.co.uk/product/rhs-sill-rail-...ion-wagon/ |
19th Nov 2019 3:49pm |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 821 |
Mid crossmember bolts directly to that bracket, only on stationwagons, not required for hard top.
Picture of ours below - |
19th Nov 2019 4:48pm |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
See also this thread in the Td5 forum: https://www.defender2.net/forum/topic70049.html
My photos are from a DCPU |
19th Nov 2019 5:09pm |
Excellent, thanks a million for all the replies. looks like the two links yrmit links are what I need. Didn't think I'd need to remove the floor panel though....
Great Forum. |
19th Nov 2019 6:58pm |
Parts arrived from YRM , so spent the afternoon cutting and grinding out the old x-member and mounting brackets (light faded so will take pics tomorrow).
YRM looks to be a solid bit of kit. I just tried a dry run of fitting it before I finished up this evening, having removed the triangular panel behind the second row doors I can't see it fitting in one piece. In order to save removing all the floor panels I was thinking of cutting it in half and inserting from either side and bolting it back with three (both sides and top) galv plates when in situ.... Any observations, comments or warnings to doing this would be greatly welcomed. |
1st Dec 2019 5:27pm |
I wouldn't cut the new galvanised x-member. Remove the floor panel behind the front seats. It takes a while if the bolt heads are rusted brittle, but you can then replace them with something shiny. Having the floor out also means you can apply some corrosion protection wax to the exposed chassis section.
1st Dec 2019 5:43pm |
