Home > Tdi > 110 CSW chassis/body mounting bracket
Walty84
Hey.... Greetings from Ireland,
Just wondering if anyone could point me in the right direction with the correct name of the bracket/parts I need to replace in the picture. Having trouble identifying it from the replacement chassis parts collection...? It’s a chassis/body mounting bracket and appears to be bolt on??
Any help would greatly appreciated
Post #802788 19th Nov 2019 12:26pm
hank
Not seeing a picture? > 110 XS Double Cab
Post #802796 19th Nov 2019 12:53pm
Walty84
Sorry, was uploading from phone....Should be visible now.
Post #802798 19th Nov 2019 1:07pm
hank
Post #802802 19th Nov 2019 1:16pm
Walty84
Sorry should have said 1998 300tdi
Thanks for the links, they were actually the ones I was using for reference, however nothing there seems to marry up with mine? Im now wondering is it a body part as opposed to a chassis part....
Post #802808 19th Nov 2019 2:20pm
Walty84
Found this image online. Might show the bracket a bit better, bolt pattern circled. ??
Post #802820 19th Nov 2019 3:19pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Post #802823 19th Nov 2019 3:49pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Mid crossmember bolts directly to that bracket, only on stationwagons, not required for hard top.
Picture of ours below -
Post #802835 19th Nov 2019 4:48pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
See also this thread in the Td5 forum: https://www.defender2.net/forum/topic70049.html
My photos are from a DCPU
Post #802838 19th Nov 2019 5:09pm
Walty84
Excellent, thanks a million for all the replies. looks like the two links yrmit links are what I need. Didn't think I'd need to remove the floor panel though....
Great Forum.
Post #802857 19th Nov 2019 6:58pm
Walty84
Parts arrived from YRM , so spent the afternoon cutting and grinding out the old x-member and mounting brackets (light faded so will take pics tomorrow).
YRM looks to be a solid bit of kit. I just tried a dry run of fitting it before I finished up this evening, having removed the triangular panel behind the second row doors I can't see it fitting in one piece. In order to save removing all the floor panels I was thinking of cutting it in half and inserting from either side and bolting it back with three (both sides and top) galv plates when in situ.... Any observations, comments or warnings to doing this would be greatly welcomed.
Post #804325 1st Dec 2019 5:27pm
Intercept
I wouldn't cut the new galvanised x-member. Remove the floor panel behind the front seats. It takes a while if the bolt heads are rusted brittle, but you can then replace them with something shiny. Having the floor out also means you can apply some corrosion protection wax to the exposed chassis section.
Post #804327 1st Dec 2019 5:43pm
