Page 1233 of 1383 <123 ... 123212331234 ... 138113821383>
othorton
United Kingdom 2005 Defender 90 Td5 CSW Java Black
Treated mine to a wash and wax, ready to tackle the urban jungle of Brixton
Post #802771 19th Nov 2019 7:33am
othorton
Double post whoops.
Post #802772 19th Nov 2019 7:33am
L110CDL
Like the stance in the second pic Cool Clayton.
Keeper.
Post #802879 19th Nov 2019 8:47pm
L110CDL
I will try and endeavour to put a post on here next year when they start enrolment Thumbs Up[/quote]
Please do Rashers, if the dates work out for me, i will be up for that Very Happy Clayton.
Keeper.
Post #802880 19th Nov 2019 8:50pm
Rashers
No worries Clayton. It usually kicks off around September. I am on their email list.
On the flip side to this, I said to Sulisuli that I would try (again if the dates work) to get across to a South West meet this year. Would have liked to have done the last one, but Mrs Rashers was not well so I had to pass.
Post #802917 20th Nov 2019 8:43am
Doc P
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Replaced the battery and changed the wiper blades for winter proper. The BBUS kept sounding on starting and I thought it might solve a sticking door lock actuator (which it didn’t). Was still on the original (6 yrs old) in a daily driver, so not too bad. Put in one of those Yuasa HSB019s.
Post #803184 22nd Nov 2019 3:12pm
notxal
United Kingdom 2014 Defender 90 Puma 2.2 HT Aintree Green
Decided to replace the flat top cubby box with a Britpart Cubby box with a thicker top armrest lid. The Britpart box arrived and was of good build quality with the exception of what can only be described as cheap brass plated hinges and stay from the local DIY store!. End result was, I just swapped the thicker arm rest lid onto my OE cubby box.
Post #803189 22nd Nov 2019 3:23pm
L110CDL
Hopefully next year you can make it to a South West meet Rashers Thumbs Up Clayton.
Keeper.
Post #803250 22nd Nov 2019 9:52pm
Sulisuli
You would be very welcome Rashers Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #803252 22nd Nov 2019 9:55pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Replaced old, scuffed headlights with Wipac crystal ones with stainless steel bezel. Makes the front end much neater, Used existing bulbs and overall very easy to do Thumbs Up
Post #803305 23rd Nov 2019 2:43pm
Huttopia
In line with my technical skills, I carefully peeled the backing off the sticky back plastic and stuck the Mud vanity mirror into position. It’s only taken me 3 months to get around to it. I took the 110 off to Worcester this morning and watched my son play rugby, sadly the game was called off after 20 mins when one of the opposition was injured and an ambulance was called. After an hour and a half the ambulance still hadn’t arrived- the hospital is 3 miles as the crow flies. Just shows the pressure the system is under.
Post #803327 23rd Nov 2019 6:23pm
Roger
United Kingdom 2007 Defender 110 Puma 2.4 SW Java Black
Replaced the battery before it gets too cold. Put in a Yuasa HSB019s much like Doc P. The old battery did very well as the original on an 07 plate(!) still had the radio code stuck to the side of it, even though that has long since been swapped out!
I'm hoping that as the old battery isn't dead yet, it should encourage me to fit the split charge system that is sharing the corner of the garage with all the other 'to do' jobs. Rolling with laughter
Post #803405 24th Nov 2019 4:39pm
othorton
Went camping in High Wycombe, which was actually very pleasant. That said, Google predicted a 5% chance of rain the whole day. I should have asked them to make me some odds because it poured until 9pm. On the plus side, the defender proved its worth yet again, towing both onto and off-of the site. Using 1st gear LR just above idle it performed brilliantly. One thing that has been reinforced is the need for a roof-top tent at some point in the near future. There's something deeply appealing about not having to crawl into a gopping tent on waterlogged ground!
The 54" light bar also came into its own.
If anyone is interested in the insane camper - it's a Japanese Import Isuzu. It tells you it's turning very politely in Japanese if you put on the indicator!
Post #803474 25th Nov 2019 8:55am
excossack
Had the thermostat replaced last week and now I have some heat Smile its an improvement over none Smile still not as warm I as I remember the heat being.
Maybe matrix swapping time. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #803580 26th Nov 2019 8:02am
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
I made my first Optimill purchase last weekend , an irresistible show offer . It’s the rear number plate light with reversing camera .
Wired it up to my Pioneer screen and then to the reverse light and hey presto .
Great bit of kit and picture quality is superb .
 https://www.instagram.com/hustynminepark/
Post #803939 28th Nov 2019 11:56am
