Home > Puma (Tdci) > 110 starting issues
110 Iain
United Kingdom 2008 Defender 110 Puma 2.4 USW Chawton White
110 starting issues
110 starting issues
New to defender hoping for some help regarding starting issue.
On first turn of key get half crank then click nothing on second turn of key
She usually fires right up and is ok starting when warm so far have done earth cable
Changed relays under seat problem is slowly getting worse as it gets colder
Worried it going to pack in completely any help would be great
Post #801839 11th Nov 2019 7:59pm
First thought is battery condition, as you say it's getting worse as the weather gets colder. Darren
Post #801862 11th Nov 2019 10:19pm
110 Iain
starting issues
Sorry forgot to mention replaced batterie 3 attempts this morning on first couple of turns can hear sort of squeaking noise
perhaps starter solenoid ?
Post #801890 12th Nov 2019 9:11am
Hmm, if it's trying to crank then probably starter motor rather than solenoid. Darren
Post #801894 12th Nov 2019 9:31am
110 Iain
starting issues
Hi its strange on maybe second or third attempt it starts normally spins up fine and starts ok once warmed up its only
after she is left for a few hours or overnight first couple of turns is like a drained batt ie half a crank at most it has been doing it since i got her 4 months ago could starter motor play up only when cold ? its a ex utility so no fobs alarm etc to interfere
Post #801898 12th Nov 2019 9:42am
bankz5152
My 110 TD5 is similar.
Cold mornings first turn, half a crank, second go feels like its on 4 cylindets, little throttle and usually fires up. Third always fires up. Not an issue on warm mornings. Instagram @defender_ventures
Empire Tuning - Agent
Post #801908 12th Nov 2019 10:35am
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
There seem to be a lot of issues related to the ignition barrels. If your battery, relays and earth connections are ok I'd suspect it may be the barrel switch becoming problematic.
I'd suggest changing and my advice is only to use genuine Land Rover replacement. They sell with door barrel locks so you keep one key.
Post #801932 12th Nov 2019 1:52pm
Martin
Site Admin
You can change just the switch and so not have to change the entire keyset.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #801935 12th Nov 2019 2:28pm
110 Iain
Thanks for all advice so far will change ignition switch next
Got a britpart one will do to test hope this sorts it
And I can get back to all the other issues leaking roof dodgy door
Seals etc etc ah the joys still love the beast every journey is an
Adventure Endeavour To Persevere
Post #801963 12th Nov 2019 6:26pm
110 Iain
How easy is it to change just the switch part an I access
Side of barrel to remove ok ? Endeavour To Persevere
Post #801968 12th Nov 2019 6:55pm
skidrov
Australia 2010 Defender 110 Puma 2.4 SW Fuji White
What I did, on a MY10 110. I bought a pattern switch, for about $AU 40 delivered.
- Disconnect battery.
- Remove upper column shroud.
- Remove instrument binnacle.
- The switch is at the end of the lock assembly, remove small screw retaining it.
- Note which wire goes where, remove the (probably) 4 wires on the switch assembly (tight work space, and that harness doesn't have much slack).
- Might need to lightly tap out the old switch - tabs protrude to allow this.
- Rinse and repeat, noting that it is fiddly to line the switch up in the correct spot, as it's a tight fit with limited work space - it has to go a certain way. Finally, I used blu-tac on the end of a screwdriver to refit the small screw so I didn't loose it.
My guesstimate is a 1 to 2 hour job, go to stop. Not the worst task.
Post #801999 12th Nov 2019 9:26pm
110 Iain
So changed ignition switch with the help of a grinder to
Get old one off but still got starting problem start on3rd
Time first couple of cranks not even half a crank
Followed by squealing noise.
May bite the bullet and change starter looks a pig to do
Are there any other earth points I should check or
Could it be a poor positive connection? Endeavour To Persevere
Post #802221 14th Nov 2019 11:26am
KelvinB
Wales 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Agree with Anorack - Sounds like the starter motor to me. Had a similar thing a few months ago and was getting progressively worse until it failed completely.
Post #802757 18th Nov 2019 10:34pm
nicholas2012
Scotland 2010 Defender 90 Puma 2.4 HT Tamar Blue
Alright Iain I would have a guess at starter too.
I see you say you have a ex utility with no fobs one of my pals has the same.
His got stolen a couple of weeks ago in daytime by breaking the ignition barrel and was driven away, was very lucky to get it back after being found hidden in woods.
So might be worthwhile getting your immobiliser turned on and maybe a few other bits of security
Post #802765 19th Nov 2019 12:56am
jst
whats the voltage in the battery prior to a cold start and what does it drop to when you apply load to the starter? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #802777 19th Nov 2019 9:33am
