Home > Puma (Tdci) > 110 starting issues
Page 2 of 2 <12
110 Iain
United Kingdom 2008 Defender 110 Puma 2.4 USW Chawton White
Thanks to all will test voltage this weekend and probably change starter
As for security not sure what alarm to fit had issues in past with alarms
Currently have basic tracker Endeavour To Persevere
Post #802862 19th Nov 2019 7:10pm
Cupboard
Changing the starter on mine made a huge difference to how quickly it turns over, before it always sounded like a had a flat battery even when both batteries were fully charged. Now it turns over beautifully.
Although that wasn't my starting issue, that was fixed by wiggling the under seat relays.
Changing the starter is perfectly doable on the drive. It's one of those job where you'll spend an hour wiggling various spanners, sockets and extensions around not being able to quite reach the bolts then it will suddenly all click in to place and you'll wonder what the fuss was about. Putting it back on again is the same, spend an hour getting mad at it, skinning your knuckles on everything going then plop and it's in as if by magic.
Post #802989 20th Nov 2019 8:00pm
110 Iain
Starter changed all good now pig to get into
Coolant pipes in way need baby hands but done now
Can move on to other issues now leaking doors /roof
Erratic heater control unit leaking transfer box
Clutch rattle/ comedy window washers. Pathetic blower
Fan .but still love her and stops me watching telly
Thanks to all for help and advice Endeavour To Persevere
Post #803226 22nd Nov 2019 7:37pm
Page 2 of 2 <12
