Home > Maintenance & Modifications > Position of Dog Guard - 110 |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1036 |
I have the one from Travail. Not sure if the fittings are equivalent on the LR version.
The fixings use existing holes - top handle and the 2nd row seat fittings. Removing the seats won't help as the fixings are going to be in the same place. I suppose you could make something to move the location, but beyond my knowledge. |
11th Nov 2019 1:44pm |
Dutch G4 Member Since: 29 Jan 2015 Location: near Rotterdam Posts: 49 |
Thx for your reply AMBxx ..... when the fixings use the existing holes then i suppose it won't be possible to mount the rack any further to the front. Duct tape is The Force; is has a light side, a dark side and it holds the universe together.
11th Nov 2019 2:09pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 671 |
Maybe something like this is what you need:
https://rocknroad4x4.com/shop/load-barrier-cargo-net-defender/ |
11th Nov 2019 2:14pm |
I wanted to move the barrier closer to the back of the seats as there's a gap of nearly 6 inches. First I loosened the lower fittings and used a block of wood to move the barrier forward. Didn't work well as the wood came out too easily and it bent the bolts. In the end, I just removed the lower piece so just have the top half in place supported by a dog crate in the back (I use the barrier to stop anything on top of the crate flying through to the front in an accident ) |
11th Nov 2019 3:27pm |
