Home > Tdi > Steering help
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
Steering help
Got a load noise for the power steering pump steering went stiff the belt has slight wear on the one side .
How much resistance should there be when you turn the pump wheel? .
I've turned the steering from side to side now the noise has stopped and steering is back to normal.
Post #799795 28th Oct 2019 4:16pm
tolley
Anyone tell me if the pulley on the power steering pump should spin freely or have resistance
Post #800340 1st Nov 2019 2:42pm
dorsetsmith
At slow speed your power steering pump will spin freely only way to test the out put presser with gauge kit
see link to work shop Manual show power steering pump testing
https://1drv.ms/b/s!AtZSoWFHDgnGhUfhpexEdGpupY2Q?e=hg4MCm
Post #800357 1st Nov 2019 4:37pm
tolley
Found it.
The belt was just on the edge, looks like the shaft has come loose.
Post #801480 9th Nov 2019 11:47am
Oldowner
I’ve had a couple of shafts fail on 300tdi PS pumps over the years, end up with fore aft movement on the shaft, mileage / age doesn’t seem to come into it.
Post #801495 9th Nov 2019 2:33pm
dorsetsmith
tolley wrote:
Found it.
not good news but at lest you nailed down
Post #801504 9th Nov 2019 3:05pm
dorsetsmith
find this
key has failed
Post #801554 9th Nov 2019 8:32pm
tolley
new one fitted Thumbs Up
Post #801587 10th Nov 2019 8:35am
tolley
One I did do to the last one , was the penny trick behind the pulley tensioner to stop the belt squeaking , whether this didn't help I'm not sure.
Post #801608 10th Nov 2019 11:20am
