![]() | Home > Tdi > Steering help |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1117 ![]() ![]() ![]() |
Got a load noise for the power steering pump steering went stiff the belt has slight wear on the one side .
How much resistance should there be when you turn the pump wheel? . I've turned the steering from side to side now the noise has stopped and steering is back to normal. |
Anyone tell me if the pulley on the power steering pump should spin freely or have resistance
At slow speed your power steering pump will spin freely only way to test the out put presser with gauge kit
see link to work shop Manual show power steering pump testing https://1drv.ms/b/s!AtZSoWFHDgnGhUfhpexEdGpupY2Q?e=hg4MCm |
![]() Click image to enlarge Found it. The belt was just on the edge, looks like the shaft has come loose. |
not good news but at lest you nailed down |
find this
![]() key has failed Last edited by dorsetsmith on 10th Nov 2019 2:54pm. Edited 3 times in total |
new one fitted
One I did do to the last one , was the penny trick behind the pulley tensioner to stop the belt squeaking , whether this didn't help I'm not sure.
