Home > Puma (Tdci) > Heated seat not working... |
Multimeter and check there's power going to it and check the resistance in comparison to the other seat to see if the element may be open circuit.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
12th Sep 2015 6:09pm |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
The multi plug under the seat is a weak point. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
12th Sep 2015 6:51pm |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 595 |
Pull the seat base off, they lift up at the front, you'll need to give it a swift tug. Then have a look at the cable that comes out of the bottom of the seat, I think it goes to a block connector somewhere along the line (but that's from memory so could be wrong (although it must be connected somewhere!)), make sure the cable hasn't been snagged from a previous seat removal. The cable doesn't seem quite long enough to put the seat anywhere out the way so it might have been dislodged from one end or another.
I'm not sure if the passenger and drivers seat is swoppable but I'd try that, see if the problem stays put or changes to the other seat. |
12th Sep 2015 6:56pm |
Cuthbert Member Since: 26 Oct 2013 Location: Up North Posts: 1535 |
My doctor would day that you were a very fortunate person. He seems to have a lot of patients with a painful medical problem that he feels is accelerated by drivers heating up their nether regions. |
12th Sep 2015 8:12pm |
Cake Member Since: 10 Jun 2015 Location: Essex Posts: 277 |
Thanks all for the great info.
I will remove the seat and take a look Hopefully an easy fix Will report back with my findings incase anyone else experiences the same thing |
12th Sep 2015 8:53pm |
Thanks all just a loose connection under the seat as stated and working now
Thank you! |
13th Sep 2015 11:08am |
When I bought my one the salesman said owning a Defender is a way of life. I think that's what he meant, you'll be spending all your time fixing it.
Glad it's sorted. |
13th Sep 2015 2:05pm |
Yes I have plenty of things I would like to do but keeping it sensible.
Job 1 done which was the seat heater. Some security in its way. Next a service, then a polish, tidy a little carpet, remove the tow bar, replace some rusty bolts and that should be her 100%. Going to get Her 100% perfect as standard and then next year move to the modifications - will keep it all sensible and nothing outrageous just LR accessories - well that's the plan. |
14th Sep 2015 7:34pm |
Kent_keith Member Since: 01 Jun 2014 Location: Kent Posts: 388 |
Now winters upon us, there's a few things that need looking at that I swore I'd do before i needed them first one is my heated seats, they used to get really hot, now the passenger seat is just warm, and the drivers side doesn't work at all?
Questions What controls the heating limit? Has it a thermostat connected somewhere? And although I have supply to the drivers side coming in from the seat box it disappears up into the backrest (that doesn't work) but I could only test the seat connection which is dead? Does it daisy chain somehow, and how difficult is it to get to the backrest connection Ta 2005 TD5 90 CSW XS |
7th Nov 2016 11:50am |
Hall46 Member Since: 30 Dec 2017 Location: Ayrshire Posts: 42 |
Got this issue on my 110. Doesn't seem to be any obvious snags on the wiring and the light is coming on for the seat which I believe means there is not a fuse blown. Does anybody have a circuit diagram for puma heated seats?
29th Oct 2018 5:53pm |
Click image to enlarge Last edited by dorsetsmith on 9th Oct 2019 3:11pm. Edited 1 time in total |
29th Oct 2018 6:32pm |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1218 |
Does anyone have this wiring diagram?
Cheers Clemmo Make today a little better than yesterday but not so good as tomorrow.... Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadster……..........Vermillion 17k miles Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun |
9th Oct 2019 2:55pm |
Kevzeboy Member Since: 19 Jul 2014 Location: Cumbria Posts: 83 |
My ones work, but don’t come on that much and don’t get that warm?
Is this right, they are a bit disappointing? Kevin |
3rd Nov 2019 11:36pm |
..thats right
just takes the edge off...very welcome when it's proper cold Clemmo Make today a little better than yesterday but not so good as tomorrow.... Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadster……..........Vermillion 17k miles Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun |
4th Nov 2019 8:11am |
