Home > Puma (Tdci) > Does your Puma ever get confused
llessur
Not sure if this is the early indication of a fault or simply user error.
On two occasions now, about 2 months apart, I have jumped in the defender and started it immediately, i.e. no time for any heaters or self checks. The engine started but ran erratically / lumpy. I thought once it warmed up, it would be OK, but it wasn't. So I turn the ignition off, and restart it. from then on it is perfect and just the same as it always is.
So, did I confuse things by starting to quickly or could this be the early signs of an imminent failure.
I have checked the plugs on the ECU, yellow relay and green box immobiliser.
your thoughts are appreciated
Post #800231 31st Oct 2019 7:30pm
X4SKP
Why rush things... Question
From cold... let the Glow Plug(s) Heating Light go out then start...
'if symptoms persist'... check for any recorded fault codes.
Good Luck SKIP
Post #800314 1st Nov 2019 11:19am
llessur
it wasn't intentional, it's normally after I have been driving a petrol vehicle for a while. There were no fault codes sored so I think I will just put it down to me.
Post #800321 1st Nov 2019 12:17pm
Grenadier
Mine gets confused in sometimes thinking it's a 911. Or maybe that's the driver's fault.... Whistle Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #800332 1st Nov 2019 1:35pm
I don’t think I’ve NOT used the glow plugs on start up about 2 times in 10 years.
I use them on every start, varies in time they are active between cold start and hot start but I always use them every time.
There is a fairly significant voltage drop on start up which is something to bear in mind too. $W33T $0U7H3RN $UG4R
Post #800335 1st Nov 2019 2:01pm
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Early signs that you may need a new ignition barrel....something getting worn and losing connectivity??
Post #800336 1st Nov 2019 2:04pm
Huttopia
Can you hear the click on a Puma, I’ve never listened for it? I usually wait for it in the 300tdi, especially if it is a cold morning.
Post #800374 1st Nov 2019 6:15pm
Caterham
I would suggest it not leaving the glow plugs to go through the heat up cycle should make little to no difference with the exception of when it's very cold and then only for the first few seconds?
Post #800398 1st Nov 2019 9:04pm
grafty99
Modern diesels engines (300tdi included) keep the glow plugs activated for a predetermined time, after startup, as part of the cold start strategy. It helps with startup smoke, emissions and smoothness.
Just because the light has gone out doesn't mean the glow plugs have turned off Thumbs Up
I always wait for the glow plug light when starting a diesel Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #800425 1st Nov 2019 11:01pm
Solihull Boy
Surely this is not just a case of the Glow plugs. premature starting causes other issues.
Most modern vehicles go through a self check when the ignition is activated, during which they shouldn't be started, indeed some of the large trucks and coaches I drive will not start until this self check is completed. What's the problem with just letting the vehicle. Land Rover, or anything else complete it's self check.
As a final comment, and friend of mine has the same vehicle as me, and has had in the past various problems and glitches by being in a rush to drive away, including turbo issues, I have had none. A bit of consideration ie allowing the self check, and engine to idle briefly before driving gently till warm is called mechanical sympathy and as an 'old git' HGV/PSV held for 36 years this consideration can only be beneficial
Regards
Ged Retired from the day job and now self employed - what a life!!
Post #800570 3rd Nov 2019 10:29am
Sulisuli
GED out of interest how long after starting do you allow the engine to idle? 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #800573 3rd Nov 2019 10:43am
Solihull Boy
Hi Sulisuli,
As long as it takes me to put the seat belt on, and check no warning lights and check the mirrors ensuring it's safe to move off - maybe 20 seconds. I do the same before switching off, also, just let the engine idle for 10 or 20 seconds.
If, however I've been working it hard, towing our caravan on the motorway or about to tow on the motorway, I always allow the engine to idle for a minute or so, to ensure good oil flow.
I operate this way with whatever I'm driving and it seems to aid reliability and longevity
Regards
Post #800735 4th Nov 2019 1:20pm
