Home > For Sale & Wanted > [Wanted] Another odd request: Old Eberspacher Pump/Part |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
Annoyingly have snapped the pipe stub off the outlet on my D2 Airtronic pump.
Does anyone happen to have an old/no longer functional pump lying around which could yield a replacement for me please? It is the smaller of the two stubs I need (the one that typically isnt available separately !). Thanks in advance, Steve 02' 110 TD5 Double Cab Rebuild Thread |
23rd Oct 2019 7:05pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5852 |
Would a brake pipe fitting do the job? 1999 Defender TD5 110
24th Oct 2019 1:34pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6097 |
I looked in my old DVD drawer.... but nada....
24th Oct 2019 8:55pm |
it was worth a try!
Its a strange fitting sadly, thread must be an M4 with a sealing o-ring above. If it was the pickup side i would chance using a bit of chemical metal to seal it up. As a temporary measure (to make sure the rest of the system works) i have got a larger piece of rubber fuel hose which should just fit over the larger diameter on the fitting. Not convinced on this as a long term solution though. I did find a pump 'repair kit' on ebay for £17 but i needs to make its way here from Turkey! Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread |
25th Oct 2019 6:17am |
