Home > Puma (Tdci) > Best choice for new starter battery
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
After a bit more than 7 years / winters I'd like to replace the original battery.
I'm not sure which product is best ... do you have any ideas ?
Post #799235 23rd Oct 2019 8:48pm
G4UJS
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
I bought an Exide EA1000 from Tayna Batteries... reasonable price and is excellent.
regards
Rob
Post #799248 23rd Oct 2019 11:33pm
DEF4
Since the original battery was from Varta, I replaced mine with Varta recommended AGM battery (595 901 083 – G14). Same size and maintenance free
Post #799258 24th Oct 2019 6:05am
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
I have always used Varta on my vehicles, I really can’t fault them.
Post #799273 24th Oct 2019 9:07am
JOE_130
United Kingdom 2015 Defender 130 Puma 2.2 HCPU Java Black
If funds allow I'd always replace with an Odyssey battery, but failing that the OE battery seems fairly bulletproof in a Defender!
Post #799298 24th Oct 2019 11:10am
MartinK
+1 for G14 Varta Start-Stop Plus AGM Car Battery 12V 95Ah (Tayna part 595901085)
Got one, fast cranking, seems great! Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #799338 24th Oct 2019 3:26pm
Mdm
we use this at work
you can then take the info and cross reference it to other makes and brands
we have just swapped a 3yr old one that failed under warranty no issue
https://batterylookupgb.yuasa.co.uk/
optimas used to be good but ive had both mine fail this year without warning and they live on a ctek charger.so i cant recommend them anymore.
anything with 3-5yr warranty seems to last the distance.
Post #799376 24th Oct 2019 7:55pm
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
I replaced my battery a couple of years ago with a HD Yuasa battery and I can't fault it. Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #799377 24th Oct 2019 8:00pm
jst
I have replaced with these https://www.tayna.co.uk/leisure-batteries/numax/cxv30hmf/in my Pumas (4 of them) for last 12 years as starters. Still running 3 of them in a 110 and 2 x 90s.
I have also run them in parallel in a winching vehicle for over 10 years, and run them in series (24v) in a competition vehicle. for 8 years.
The chap who had the 10 year old batts off me when he bought the car from me (winching vehicle) was on about changing them last weekend, then found it was a wiring fault and not a battery fault!
So for the money i rate the numax. yes i know its says leisure and all that..... Shocked Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #799378 24th Oct 2019 8:10pm
ngins
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Corris Grey
For the folks that went for AGM, was there a particular reason? I have AGM in another car with stop start and I know they are also sealed which is why they are sometime fitted on cars with no stop start but where the battery is somewhere inside the cabin , but normal wet cells are pretty well sealed these days as well and I assume if I am upside down in my 110 I probably have more immediate issues than the battery to deal with Smile.
Just wanted to know if there was another reason like running additional electrics, or fancy setup with another battery for winching etc? There is probably no single reason but I just wanted to see if there was any consensus as I am tight and they are nearly twice as much as the compatible wet cell, even if you go for the improved capacity wet 019s (seems about the same price difference between their premium wet cell and AGM for exide, Yusa and Varta). So I just wanted to justify the extra cost. I appreciate it’s important to have a decent battery but I am not doing much stop start. Although I do do some short journeys it sits round a bit. I suspect it’s just personal preference but wanted to make sure I haven’t missed anything obvious.
Thanks!
Post #811847 25th Jan 2020 8:48am
Bluest
The nearest equivelent to the OEM battery is the Varta LFD90 I think. It was discussed at length on here in a previous thread a few years ago.
Regarding AGM, they require a higher charge voltage than flooded batteries to charge properly and I don’t think the Puma alternator goes high enough. I’m sure I read they need 14.7v ideally. The highest I’ve seen from my car around 14.4v 2007 110 TDCi Station Wagon XS
Post #811849 25th Jan 2020 9:07am
ngins
Cool. Thanks. I saw on this thread a few folks got the Varta AGM so was just interested. Mine still seems to be going ok but it’s done 6 years which isn’t bad going for a car battery so I am carrying jumper pack around just in case but for 100 quid I should probably just change it out.
Post #811894 25th Jan 2020 3:06pm
DEF4
Here is relevant information given on the Varta website: https://batteryworld.varta-automotive.com/en-gb/advantages-agm
Post #811994 26th Jan 2020 7:33am
ngins
Very useful info. Thanks all. Thumbs Up
Post #812041 26th Jan 2020 12:33pm
