Home > Puma (Tdci) > Duff defender ?
Page 2 of 3 <123>
Martin
Site Admin
No it won't show as a fault code, it's a purely electrical on/off problem. You might get some spurious codes due to things shutting down when.
You don't need to change the whole barrel and keys, just the switch on the far end of the key barrel/column lock - part number LR039638
Can you let me know what you mean about the dash lights above?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #799109 22nd Oct 2019 10:01pm
Nick90pickup
Morning Martin,
Thank you for the part number. I shall get that on order. I shall see if there is a you tube video on how to do it.
The dash reference was just to say there was no engine management light coming on or otherights to indicate a fault.
If this is the problem it would be amazing to fix it.
If anyone has any tips on changing the part it would be great to know about them
Post #799126 23rd Oct 2019 6:09am
JOW240725
Where abouts in Suffolk are you? I might be able suggest a few garages.
Any AS10/ECU electrical issues I'd speak with Dan Padmore at Pace Automotive, Peterborough. However, I noticed on FB that he's on holiday at the moment. James
Instagram @suffolk_rovers
Post #799143 23rd Oct 2019 10:40am
Martin
Site Admin
Are you getting NO dash lights (or just the battery light), or is the glow, oil pressure and MIL (and temp gauge) working ok?
Thinking about it again, remove the starter relay, turn the ignition on and bridge the starter relay power terminals with a thick wire. Pull the wire out quickly if it starts!!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #799147 23rd Oct 2019 11:28am
Nick90pickup
Hi Guys,
I am Bury st Edmund's. The dash light are all normal and as you would expect when trying to start the engine.
I have ordered the ignition switch from landrover which should be here tomorrow. Fingers crossed that does something productive
Post #799155 23rd Oct 2019 12:52pm
JOW240725
I've not used them myself yet, but I've been recommended M C C Motor Engineering, Fish Farm Ind Est/Tut Hill, Bury Saint Edmunds IP28 6LE, Phone: 07760 241096.
Hope you get it sorted. Thumbs Up James
Post #799159 23rd Oct 2019 1:18pm
Nick90pickup
Thanks very much,
She has already been to MCC and they could not find any fault. Then it went to Mansfield and they could not get it to fault while plugged in.
The auto electricians machine was not the right one for the job ( so he said after he invoiced)
The lock smith found no fault and did have it fail to start on him. Then got it going and assumed it was fixed.
No she is dead as a dead thing Shocked
Post #799177 23rd Oct 2019 2:51pm
Martin
Site Admin
Tried starting it my way? Key switched to ignition (dash alive) then bridge the starter relay to send power to the starter?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #799180 23rd Oct 2019 2:56pm
Nick90pickup
Not as yet,
So that trun the key and use a jump lead or something to the starter?
I used to start old tractor with a screen driver across the starter motor. Not sure if that's similar wlto what you mean ?
Post #799188 23rd Oct 2019 4:12pm
Martin
Site Admin
No I didn't mean straight to the starter but at the relay under the seat.
I was trying to see if the feed down to the relay from the starter switch was duff, but your new switch tomorrow should answer that anyway.
Just a note when you come to change your switch. Make a note (or take a photo) of where the connectors go as they go individually. Easy to mix up. Pic below for reference:
2015 D90 XS SW
Post #799189 23rd Oct 2019 4:22pm
Nick90pickup
Thank you that's a great tip.
I have got an ebay special and if it works I shall get a real landy one. Hopefully it's an easy job
Post #799193 23rd Oct 2019 4:38pm
Martin
Site Admin
Here's another idea. Idea Laughing
Before you get into the hassle of removing the old switch, leave it in place and swap the wires onto the new switch and operate it using a screwdriver.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #799202 23rd Oct 2019 5:45pm
Nick90pickup
That sounds interesting. Is that as basic as it sounds ?
There is not much room for my fat hands. I have already started getting anything I can off.
Lastly, i dont suppose it matters but when it did start all those month ago when you went off roading the key used to fall out. Or as I found put you could just pull the key out while you were going alone. This would have no effect on the engine. I assume this is just a landy quirk and does not have an impact on it not starting now?
Though perhaps the barrel might be worn ( I am clutching at starws i know )
Thanks
Post #799207 23rd Oct 2019 6:08pm
Muddybigdog
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Zambezi Silver
I am about as much use as a gorilla in boxing gloves in regards to electrical stuff, but if you need a tow locally I am based just outside Bury St Edmunds Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold
D3 - 2.7 S x2 (both Sold)
Freelander 2 HSE - Sold
Freelander 1 - Sold
Disco 2 - Sold
Post #799237 23rd Oct 2019 8:51pm
Nick90pickup
Thank you. That's very good of you. Hopefully today is the day she starts! If the part turns up
Post #799257 24th Oct 2019 6:00am
Page 2 of 3 <123>
