![]() | Home > Wheels & Tyres > HD wolf wheels, OEM or...? |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6168 ![]() ![]() ![]() |
Those zero offset ones looks good as well.
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7918 ![]() ![]() ![]() |
I have the 4x4tyres.co.uk Wolf STYLE ET0 rims, I have no quality concerns and balanced up fine, very pleased with them and a decent price too!
![]() Click image to enlarge ![]() Click image to enlarge James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 675 ![]() ![]() ![]() |
Hi have the "style" ones too. I think I got them from Paddocks.
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3483 ![]() ![]() ![]() |
Depends if the load rating bothers you or not 1951 80" S1 2.0
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1886 ![]() ![]() |
Pretty sure I heard the load rating was higher than genuine and web-site says 1,250kgs but confess I am not sure how that compares
![]() 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
Load rating of a genuine Wolf wheel is 2.200 kg.
Dan from Duckworth once posted
Only just seen this thread, unfortunately don't get time to go through every post, drop me a PM with any questions more than happy to reply. Genuine ANR5593PM Tubed, Primed HD Wolf Steels 3500kg rating �84.50inc vat each ANR4583PM Tubless, primed HD wolf steels 3500kg rating �74.00inc vat each 2014 so prices won’t be right ![]() 1995 110 300TDI 1995 90 300TDI |
Hmmm on that basis guess I’ll be powder coating my genuine wheels at the same cost as buying new aftermarket
No disrespect to Dan but there's no way that the load rating of an HD steel is 3500kg's. If that were true then there would have been no need for vehicles like the WIMK to use Blindo's. It depends which website you read but the actual rating is likely to be 1500kgs. Aftermarket versions seem to vary a bit but the Terrafirma ones I've just fitted are also rated at 1500kgs. By comparison, the ones that Craddocks sell are claimed to be rated at only 1080kgs. Even that lower figure is not dissimilar to that of Boost alloys, so it's not really an issue for 90's and 110's. 130's do require a higher rated wheel though, hence never being supplied with Boosts. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
As I said, it depends on which website you read. For example:
https://www.brit-car.co.uk/product.php/821...er_classic Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 588 ![]() ![]() ![]() |
quite cool in 8 x 16
![]() Click image to enlarge https://www.nakatanenga.de/en/vehicle-equi...l-rim-8x16 |
![]() Click image to enlarge Nakatanga’s from https://www.mudstuff.co.uk/nakatanenga-anr...wheel.html Photo from Saturday. Yes. Sunny! I'm also a fan of the 4x4tyres wolf et0’s ![]() Click image to enlarge |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17726 ![]() ![]() ![]() |
Genuine Wolf rims (ANR5593 tubed and ANR4583 tubeless) are rated at 2200kg per rim. Blindos are rated 1550kg per rim. When Snatch and WMIK were introduced, the standard rim was ANR1534 rated at 1372kg per rim, hence the use of Blindos. Genuine rims have recently increased massively in price (thanks, Landrover!) and will now set you back around £145 per rim. Dan's reply may have been on the basis that Wolf rims are fitted to all 3500kg GVW Defenders, there is probably misleading product data associating these rims with a 3500kg vehicle weight. |
