Home > Wheels & Tyres > Dynabeads in rear tyres? |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1841 |
^^^ Ha ha!
Maybe for all you modern soundproofed guys with Pumas and later.... I had them in the fronts on my 300tdi for a while, and will likely give them another go, but there was no chance of my hearing them.... I wonder if they might be audible and low speeds off road?? But I'd imagine not. Lookign forward to other replies. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
11th Oct 2019 7:35am |
I just have this mental image of the sound dried chickpeas would make in an inflated balloon... Boing boing shhhhhh clatter... . At every traffic light and junction... |
11th Oct 2019 7:42am |
deaallen Member Since: 15 Feb 2016 Location: Basingstoke Posts: 264 |
Are there any fitting centres for these in UK or is it a job for the driveway?
11th Oct 2019 8:12am |
Looks as if you can do it on your driveway, but yo'll need a valve removal tool and an air pump.
Seriously tempted to go for these... |
11th Oct 2019 10:54am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20367 |
Yes, you can do it at home. You’ll need a decent compressor or at least plenty of time if a cheap one.
There isn’t any noise whilst in use. I would check prop shaft UJ’s too, they are prone to causing issues at certain speeds. In fact it was this that caused me to fit the Dynabeads in the first place which didn’t solve sole the issue. The Dynabeads are great but if you have a failed UJ cup with dead bearings that will send and unbalance right back and will make you feel like there is a wheel problem. Worse than that, on mine you couldn’t tell the UJ was screwed without the prop off however hard I tried and various places never noticed either. Typically it’s the rear most UJ that’s the culprit, mainly due to angle as BW has suggested many time it’s a Puma thing due to the more extreme angle of prop rotation on the rear in relation to the T Box. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
11th Oct 2019 11:31am |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3675 |
Interesting. My commute is about half an hour at 55mph. First 10 minutes were terrible, but then smooth as you like after that. Any thoughts?
11th Oct 2019 12:44pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2227 |
Do you have wheel spacers fitted? I assume you have alloy wheels in any case?
If so it would be worth taking them off and making sure the hub mating faces are spotless. The smallest bit of debris can cause a mild wheel wobble at the speeds you describe. I have dynabeads in my 255/85 BFG MTs with no other balancing and there is no wobble at all. You cant hear the beads at all in service. By nature they are only free to roll around in the tyre at very very low speed. Steve 02' 110 TD5 Double Cab Rebuild Thread |
11th Oct 2019 1:09pm |
Got wheel spacers fitted, will double check The faces This weekend, but it was fine before the beads we’re installed. Tonight it was terrible for a couple of minutes, smooth for 5, terrible again all the way home. I’ll call dyna bead on Monday, but I also have a suspicion there could have been water in the airline I used 🤦♂️. Anyone experienced this?
11th Oct 2019 5:21pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
Going to give these a go in mine and on the RIB trailer
11th Oct 2019 6:30pm |
Just spoke to the guys at dyna bead; super helpful. Thought is that I actually have too much weight on there. I’ve got 125g weights on the rims and 6oz of beads. They would recommend 6oz of beads and no weights, so I’ll mark them up, take them off and see how it is. Watch this space.
11th Oct 2019 6:40pm |
Good advice I guess
11th Oct 2019 6:43pm |
I've not had any problems with mine with both but could be variable. $W33T $0U7H3RN $UG4R
11th Oct 2019 7:01pm |
What tyres are you using Steve?
12th Oct 2019 6:36am |
255/85/R16 KM2’s on Boosts with standard spec weight Dynabeads and balancing weights on the inside of the rim that was fitted before the Dynabeads.
Are you sure they were balanced correctly in the beginning or have you lost one? $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
12th Oct 2019 10:07am |
