Home > Puma (Tdci) > Puma Maintenance Schedule - Definitive Guide |
The Fox Member Since: 24 Mar 2014 Location: Shrewsbury Posts: 94 |
In addition to this, that is...
Click image to enlarge I'll start: 50,000 Miles :: Replace axle and transfer box oil 100,000 Miles :: Replace gearbox oil |
7th Aug 2017 10:38am |
Well, if it is your pride and joy, do you really want to wait that long to replace the gearbox and transfer box oil?
I'm not impressed with this Land Rover schedule where you can wait until a next life before replacing gear/transfer box and axle oils. Or replace the coolant fluid only after 200.000 km. Common sense tells me otherwise. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
7th Aug 2017 11:00am |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello The Fox
In addition... Click image to enlarge I completely agree with ericvv... The Maintenance should match the work tackled, but even if this is predominately road use, there is a lot of mechanical movement through the Transmission and Running Gear, swapping out all these with good quality Oils and Grease, at 50% (or sooner) than the recommended LR Schedules, is a wise move in my opinion. To be fair to LR, they do advise a significant reduction in operation time between maintenance with 'Arduous Usage'... Close Up... Good Luck... SKIP https://www.defender2.net/forum/topic83242.html |
7th Aug 2017 12:34pm |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 |
been staring at the last picture for ages, did anyone else notice its a series 2 rather than a Puma?
Took me a while though |
7th Aug 2017 5:14pm |
Don't be silly you'll have to replace them long before then due to leakage anyway. To be fair the Japanese have been using sealed for life coolant for decades. And Land Rover do specify much lower change intervals if you work the vehicle hard in dusty/wet conditions or extremes of temperatures. It never hurts to change more often than needed, although it may just be a waste of money. |
7th Aug 2017 6:58pm |
So I started writing this for my own reference, but if it's useful for anyone else I added a disclaimer and used your input:
Click image to enlarge Click image to enlarge Click image to enlarge |
10th Aug 2017 3:56pm |
cartoonhead Member Since: 02 Mar 2018 Location: Bucks Posts: 135 |
These look great have you got a PDF at all? @tab.travels on instagram
Defender 130 2.2 TDCI Defender 90 TD5 80" CCV Trialer 4.6 V8 (14CUX) Stage One V8 109 - 3.5 V8 Stage One V8 109 - 4.6 V8 (GEMS) - in progress Range Rover L322 4.4 TDV8 Freelander 1 2.0 TD4 |
8th Aug 2018 2:37pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2048 |
I’ve been looking for a 2.2 puma service schedule PDF as a nice way of recording the service work I undertake, and really like the Defender2.net one above. Was a copy ever posted as I would really appreciate a copy to use myself.
Also is there a landrover one for the 2.2, as per the 2.4 one posted at the beginning of this thread. I have searched but can’t find one here or on line. |
29th Sep 2019 11:51am |
Sorry for the delay here, PDF of what I use is attached.
Hope it's useful to someone else. https://www.defender2.net/gallery/albums/u...hedule.pdf |
8th Oct 2019 2:53pm |
GEllis Member Since: 21 Nov 2013 Location: Cornwall Posts: 58 |
Great - very useful guide.
8th Oct 2019 3:56pm |
Mr Fox... you are a star...many thanks.
8th Oct 2019 4:23pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1081 |
Very good. Would it be too much to ask for the "source" (Excel? Word?) so I could change some details for my own needs? |
8th Oct 2019 5:54pm |
macfrank , you can open a PDF in word and it will auto convert into word format.
To do :- Download PDF file , Open Word , click on file, then open , then computer . Select directory in which downloaded file resides , a pop up box appears and in the pull down box above "file" and "cancel" buttons ( lower right hand side of pop up box) select PDF as file type. All pdf files now show. Click on the puma schedule pdf file you downloaded to highlight it and then click on the open button. It will now convert to word and you can edit and save. That's what I just did |
10th Oct 2019 3:02pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7907 |
Very useful, thank you James
10th Oct 2019 3:44pm |
