Home > Puma (Tdci) > How to bleed fuel system 2.2 Tdci
Eric_H
Netherlands
Hi,
Can anybody tell me how to bleed the fuel system on the 2.2 Tdci? the 2.Tdci didn't have a fuel lift pump; but does the 2.2 have one?
I probably need to disconnect one fuel line and use a hand pump to suck the fuel through (as I did with the 2.4) but I don't know at which point I should disconnect.
Or should a 2.2 start without bleeding after there is air in the system?
Regards
Eric
Post #796319 2nd Oct 2019 10:52am
williamthedog
There's a pump in the tank on 2.2s. Thumbs Up
Post #796320 2nd Oct 2019 10:57am
Big Harold
Australia 2015 Defender 130 Puma 2.2 HCPU Alpine White
Just turn the key to the start position and you will hear the pump run. Do this a couple of times then you are good to start.
Post #796321 2nd Oct 2019 11:17am
Eric_H
Netherlands
so the same way like the Td5? But on the Td5 I can hear the pump; should I also hear the pump at the Tdci?
Post #796658 4th Oct 2019 10:56am
R1200GS
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Keswick Green
Yep, I can hear the pump on mine every time
Post #796679 4th Oct 2019 12:59pm
foggydave
United Kingdom 2014 Defender 110 Puma 2.2 USW Bonatti Grey
To prime my old Td5 I used to turn the ignition key but not start engine then pump the accelerator 7-8 times and then the pump started to self prime.
Post #796860 5th Oct 2019 9:05pm
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi,
Ok, there is a pump.
Did somebody already try to put a empty fuelfilter and let it fill automaticaly.
I always fill it with diesel and with the risk ...
Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #796877 6th Oct 2019 4:49am
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
This procedure works fine for mine for 4 years now
Post #797014 6th Oct 2019 7:58pm
Phil VM2.5
Hi,
Why did Land Rover not that simple way ?
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and
1987 BMW GS80
Post #797019 6th Oct 2019 8:23pm
