![]() | Home > Puma (Tdci) > How to bleed fuel system 2.2 Tdci |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
There's a pump in the tank on 2.2s.
Big Harold Member Since: 09 Jul 2018 Location: nsw Posts: 71 ![]() ![]() ![]() |
Just turn the key to the start position and you will hear the pump run. Do this a couple of times then you are good to start.
Eric_H Member Since: 09 Jan 2014 Location: Limburg Posts: 6 ![]() ![]() |
so the same way like the Td5? But on the Td5 I can hear the pump; should I also hear the pump at the Tdci?
R1200GS Member Since: 12 Jul 2015 Location: Hampshire Posts: 265 ![]() ![]() ![]() |
Yep, I can hear the pump on mine every time
foggydave Member Since: 29 Nov 2012 Location: Midlands Posts: 263 ![]() ![]() ![]() |
To prime my old Td5 I used to turn the ignition key but not start engine then pump the accelerator 7-8 times and then the pump started to self prime.
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 ![]() ![]() ![]() |
Hi,
Ok, there is a pump. Did somebody already try to put a empty fuelfilter and let it fill automaticaly. I always fill it with diesel and with the risk ... Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 588 ![]() ![]() ![]() |
This procedure works fine for mine for 4 years now
Hi,
Why did Land Rover not that simple way ? ?. Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
