Home > Puma (Tdci) > New axle or repair the original |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17320 |
Now that I like, greatly. £1300 approx plus VAT is mentioned in the article, which is probably not dissimilar to Genuine Parts prices. There is also the option of and LSD with full lock capability, something I've always wanted. I think you may have cost me some cash with your post! |
5th Oct 2019 7:06pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7987 |
Kam have never really performed in my opinion for their shafts, diffs. In the off road world they were always playing catch up to Ashcroft's. I haven't experienced this axle option but my money would be looking at different fabrication options. Spidetrax, acerni racing etc. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
5th Oct 2019 7:23pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20282 |
Does D44 / King do anything or is it suspension etc only? ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
5th Oct 2019 8:50pm |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 |
After further reading it appears that KAM were bought out by Allmakes
Ribble Valley stock them . They cost less than a genuine LR axle ! http://www.ribblevalley4x4.com/allmakes/AM_KAM740.html https://www.instagram.com/hustynminepark/ |
5th Oct 2019 9:47pm |
130 Dreamer , thank you . I may well be in touch . I’m waiting to hear back from someone local first .
It’s just the casing I’m after as I have all new running gear ! Is an early TD5 a straight swap ? https://www.instagram.com/hustynminepark/ |
5th Oct 2019 9:50pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4194 |
Those heavy duty axles look like they weight a lot more than standard. The Defender has a bad enough ride quality as it is, so I’d be worried about the effect of increasing the unsrpung mass by significant amount. Could get unbearable. At the very least there’d need to be some careful consideration of springs and shocks to keep it all under control. 2007 110 TDCi Station Wagon XS
6th Oct 2019 8:07am |
when i fitted Force9 internals and ends to my axles it significantly improved the stability of the vehicle in the rough stuff with the low down weight the upgraded parts added. i did go to fox +5 remote res at the same time and hydraulic bump stops. Cheers
6th Oct 2019 9:40am |
