![]() | Home > Td5 > DCPU rear load liner |
I just used some rubber coin mat cut to fit (well approximately)
![]() Click image to enlarge The additional mat with the upturned edges is a recycled Freelander rear cargo mat. |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 747 ![]() ![]() ![]() |
I used rubber flooring matt off Amazon:
2m x 1.2m | Fine Ribbed Rubber Garage Flooring Matting | 3mm Thick Floor Roll £29 It looks like the original Landrover matting. |
That would work 👍
However, the ribbed and even the 5 bar mats make sweeping out with a brush a real pain. OK if you what to lift the whole thing out and tip upside down but not so good if trying to leave I situ. |
I've laid it down so the ribs are front to back not across so sweeps out fairly easily
A man with a plan ~ I salute you Sir
I did silent coat and foam covered with ply and the matt stuck down on the ply with a further loose matt on top. Nice and quiet now
Shuggy110 Member Since: 25 Mar 2018 Location: Perthshire Posts: 58 ![]() ![]() ![]() |
Thanks - sounds good. I’ve got some insulation to put down so will buy some rubber roll from Amazon.
BTW, good looking dog! |
![]() He's a bit bigger now and pretty much a constant companion 24/7. I now know the meaning of a velcro dog. ![]() |
