Home > Td5 > Removing safari snorkel |
I think you about covered it, just the outer grill
25th Sep 2019 2:37pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4227 |
There'll be three bigish holes in the wing were the snorkel is bolted through that you'll beed to cover or fill somehow 2007 110 TDCi Station Wagon XS
25th Sep 2019 4:04pm |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 930 |
Ok, thanks to both, sounds like I don't need to get any more parts other than the vent Yes the holes in the wing, thinking about some blanking grommets at the moment as best option and maybe paint them the body colour.....
25th Sep 2019 4:58pm |
As an update, and for others wanting do the the same with a td5, if you have a genuine safari snorkel you will need a lower air intake pipe section and an upper part that connects to the vent hole that would have been removed, plus the vent cover. Obviously they all differ slightly depending on what snorkel you have and engine.
3rd Oct 2019 3:55pm |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1230 |
Hi Mike. Post some photo's when done if you get a chance 1984 One-Ten CSW
2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 |
3rd Oct 2019 8:37pm |
I will do Richard, or pass the information onto Alan for you. Unfortunately it looks a real pig of a job to get to the bolts on the inside of the wing from the engine bay.
In the meantime I will need to get the pipe sections and vent, so may be a while before I actually remove it. Mike |
4th Oct 2019 6:57am |
