Home > V8 > new cam |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1116 |
anyone fitted a new cam to a 3.5 also chain , lifters any good info help would be
1st Oct 2019 6:19pm |
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 |
Hi I did this in my V8 Discovery 1 some 7 years ago and got all the bits from RPi Engineering. Could not believe the slack in the old cam chain when it was removed!
Just take your time and label everything as you take it off! Cheers Don. |
2nd Oct 2019 7:47am |
Make sure you submerge the followers in oil for a day or so before fitting.
2nd Oct 2019 10:10am |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 |
seems useful
http://thebritishcar.com/showthread.php?90...tall-guide Also i think you need to run at 1800 to 2000 rpm for 20 mins or so that the camshaft can harden. (this was mentioned on Wheeler Dealers when they did a cam change on a V8 ). Others more knowledgeable than me should be able to confirm. |
2nd Oct 2019 11:25am |
I was thinking of renewing the camshaft ,tappets , timing chain , push rods and rocker shafts and thing else I should look for.
what would a it cost to get this done by a recondition shop , if I cant find the time to do it ? |
7th Oct 2019 2:17pm |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 |
You should also consider replacing the rockers, camshaft chain wheel, crankshaft chain sprocket, any oil seals you disturb, rocker cover gaskets, flame traps and dependent upon the type you have, the cylinder head bolts. It is not a Defender, it is a One_Ten
7th Oct 2019 3:44pm |
7th Oct 2019 5:45pm |
