Home > Technical > Strange heater issue on puma |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
Probably the valve sticking on hot under the bonnet
29th Sep 2019 6:47pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1940 |
Hi Mick wouldn’t both sides be the same? 2023 Defender L663 V8
2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) Last edited by bear100 on 29th Sep 2019 7:07pm. Edited 1 time in total |
29th Sep 2019 6:54pm |
No, the Puma heater always provides more warmth to the left side than to the right side of the truck. That’s a heater matrix mis design issue. There is a LR fix for it, but that is a dash out job.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
29th Sep 2019 7:04pm |
not what I wanted to hear!
Any idea on the fix ericvv 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
29th Sep 2019 7:09pm |
Check the valve 1 st it’s easy
29th Sep 2019 7:11pm |
Sorry mick what am I checking for, just googled a picture is there a leaver or switch on the valve I should check for movement?
29th Sep 2019 7:16pm |
https://www.defender2.net/forum/topic54969.html
This it’s on a cable the butterfly sticks |
29th Sep 2019 7:27pm |
Here you go. Mind this is just the fix for the difference between left/right side heater output. Nothing to do with a stuck valve not allowing fully cold air. Eric https://www.defender2.net/gallery/albums/u..._fix~0.pdf You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
29th Sep 2019 7:33pm |
Cheers mick
Wow that’s hell of a job ericvv thanks for the link, I don’t think mine has that issue though it’s been fine for the last 9 years and just recently started, theres a big difference between the both sides, drivers is quite cold but the passenger side warm almost hot 🥵 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
29th Sep 2019 7:49pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17526 |
Be aware that this doesn't fix anything, it's a nasty (expensive) bodge which lessens the discrepancy. A custom cross-flow heater matrix would be the only solution. |
29th Sep 2019 8:50pm |
cold Member Since: 15 Dec 2018 Location: Yorkshire Posts: 118 |
I had a problem with the left side cold right side warm - the solution was a top up of aircon gas
30th Sep 2019 6:37pm |
Thanks blackwolf
Cold I is was thinking the same because the cold setting wasn’t really that cold and on some occasions you could see the cold vapour from the air vents when working correctly, which I haven’t for a while, I may try that first It’s only around £30 for a re-gas 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
30th Sep 2019 7:18pm |
