Home > Wheels & Tyres > Michelin latitude cross
Page 2 of 2 <12
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Cupboard - would you perhaps have the metric measurements of the 7.50/R16 please? Thanks !!
Post #762627 9th Mar 2019 5:53am
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Cupboard wrote:
It should be noted that the Michelins do not have the 3 peak mountain snowflake symbol but the BFG KO2 does.
Given a choice of 7.50 or 235 I'd choose 7.50, but given a choice of BFG KO2 or Michelin Latitude I'd go BFG (or Cooper).
A 7.5 R 16 with snowflake mountain doesn't exist (for speed index Q or S).
I have used my Michelin Lattitude Cross Tyres for 90000 km / 6 yrs
No problems on roads, dry terrain and sand (ways with loose rocks are possible while driving carefully)
Post #795307 26th Sep 2019 10:25pm
spudfan
Ireland
265/75-16 according to Land Rover's Working in the Wild handbook. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #797383 9th Oct 2019 10:43am
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
I've recently gone from 7.50 R16s on standard steel wheels to 235/85/R16s on genuine LR Wolfs, both sets of tyres being Latitude Cross, and the 235's tread and overall width are a little bit wider than the 7.50s. That's measuring them rather than going on a spec sheet incidentally.
Post #797395 9th Oct 2019 11:53am
AMBxx
So metric tyre sizes still include the wheel diameter in inches? Confused
Post #797404 9th Oct 2019 12:49pm
OsloBlue
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
All for the record I went for Conti cross contacts. I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html
Post #797409 9th Oct 2019 1:15pm
spudfan
Ireland
Yep. My tyres are 235/85/16
Seems there is no standard width for the 7.50 R16. Some can be slightly wider than others. The height will be the same. 1982 88" 2.25 diesel
Post #797415 9th Oct 2019 1:54pm
A 7.50 R 16 tyre expressed in metric terms would be a 190/100 R 16, i.e., 190mm tread width with a 100% aspect ratio.
A 265/75 R 16 tyre will be about 3" (75mm) wider and approx 3/8" (10mm) taller than a 7.50 R 16.
265/75 R 16 and 235/85 R 16 are both approx the same diameter (i.e. within about 3/4") as a 7.50 R 16, but are both significantly wider.
Post #797423 9th Oct 2019 3:05pm
Joe the Plumber
My 235s are a bit wider than the 7.50s but only a bit. In fact I was quite disappointed at the difference when they arrived.
The actual tread is only about 5mm wider although it's perhaps 30mm across the sidewalls.
Post #797442 9th Oct 2019 5:04pm
spudfan
Ireland
Thanks for that. I did not mean to mislead anyone, I just took the info from the Land Rover manual.
Whoever thought you could have conversations about tyre sizes? That's another trait that sets us Defender men apart from the rest of humanity. Whistle 1982 88" 2.25 diesel
Post #797474 9th Oct 2019 7:41pm
Page 2 of 2 <12
