Home > Td5 > Front interior door light wiring |
up the A pillar out just under wing in to engine bay
24th Sep 2019 8:10pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5868 |
Cheers. 1999 Defender TD5 110
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
I dont know if it helps but one of mine was broken and wouldnt set off the alarm or interior light.
As a temporary repair I ran a wire from the door pin on the broken side up the A pillar and behind the dash top to the wire on the opposite side. End result is both doors operate the light and the alarm again. It was 3 yrs ago and it works so well I've left it. 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
25th Sep 2019 4:21pm |
Cheers for the tip - if it comes to that. 1999 Defender TD5 110
25th Sep 2019 5:52pm |
SteveK Member Since: 21 Jan 2015 Location: Bromsgrove Posts: 333 |
If it is the O/S front wire, it will probably go to the ECU.
25th Sep 2019 8:47pm |
Thanks. 1999 Defender TD5 110
26th Sep 2019 7:32am |
AS10 alarm unit My1999 Click image to enlarge My 2002 Click image to enlarge My 2002 Click image to enlarge |
26th Sep 2019 7:40am |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5213 |
has the switch gone on the bink or the light loom? I did buy a loom for my TDi for the rear, so its here gathering dust. ( just plugs into the loom on the roof) mine had rotted out badly The door switches you can rob off any rover. I robbed mine off my rover metro. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
29th Sep 2019 1:07am |
I need to do some mods. 1999 Defender TD5 110
29th Sep 2019 8:35am |
The switches are not expensive if you need them. About £2 each if I remember right 2014 - current ..... 2003 defender td5 90 (my car)
29th Sep 2019 6:49pm |
Thanks Gazman 1999 Defender TD5 110
30th Sep 2019 7:41am |
