Home > Td5 > Front interior door light wiring
excossack
What route does the cable from interior light door switch take ? I need to replace the wire but other than being inside the kick panel I am not sure what route the wire takes. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #794926 24th Sep 2019 7:32pm
dorsetsmith
up the A pillar out just under wing in to engine bay
Post #794931 24th Sep 2019 8:10pm
excossack
Cheers. 1999 Defender TD5 110
Regards
John M0VAZ
Post #794932 24th Sep 2019 8:10pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I dont know if it helps but one of mine was broken and wouldnt set off the alarm or interior light.
As a temporary repair I ran a wire from the door pin on the broken side up the A pillar and behind the dash top to the wire on the opposite side. End result is both doors operate the light and the alarm again. It was 3 yrs ago and it works so well I've left it. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #795073 25th Sep 2019 4:21pm
excossack
Cheers for the tip - if it comes to that. 1999 Defender TD5 110
Regards
John M0VAZ
Post #795090 25th Sep 2019 5:52pm
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
If it is the O/S front wire, it will probably go to the ECU.
Post #795132 25th Sep 2019 8:47pm
excossack
Thanks. 1999 Defender TD5 110
Regards
John M0VAZ
Post #795159 26th Sep 2019 7:32am
dorsetsmith
AS10 alarm unit
My1999
My 2002
My 2002
Post #795160 26th Sep 2019 7:40am
Procta
has the switch gone on the bink or the light loom? I did buy a loom for my TDi for the rear, so its here gathering dust. ( just plugs into the loom on the roof) mine had rotted out badly The door switches you can rob off any rover. I robbed mine off my rover metro. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #795705 29th Sep 2019 1:07am
excossack
I need to do some mods. 1999 Defender TD5 110
Regards
John M0VAZ
Post #795731 29th Sep 2019 8:35am
gazman
The switches are not expensive if you need them. About £2 each if I remember right 2014 - current ..... 2003 defender td5 90 (my car)
Post #795863 29th Sep 2019 6:49pm
excossack
Thanks Gazman 1999 Defender TD5 110
Regards
John M0VAZ
Post #795967 30th Sep 2019 7:41am
