Home > Puma (Tdci) > Hitch Adapter Plate |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17450 |
The four smaller holes are ISO M12 coarse series threads (1.75mm pitch), the two larger ones are ISO M16 coarse series (2mm pitch).
If your chassis is galvanised you will have to "chase" the threads on all the holes before a fastener will fit. |
20th Sep 2019 6:45pm |
MGRGPGBG Member Since: 19 Dec 2017 Location: New York Posts: 67 |
OK - thanks - if that is the case then what I though were M14 threads are actually M16 that are clogged up from galvanizing also! I will get the taps and correct bolts.
20th Sep 2019 7:32pm |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 400 |
Definitely M12 and M16, so yes you need a thread tap or two! ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
21st Sep 2019 8:27pm |
Thanks for the help on this topic.
23rd Sep 2019 11:45am |
