Home > Technical > Part SWO500030 - Wabco ABS shuttle valve |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 822 |
All since my ABS has thrown a fault I’ve been looking for a solution short of buying a new / refurbished unit
In my search I’ve come across part no SWO 500030 Now my repair guy has a disco pump and said he could cannibalise it and take the part to repair my ABS Seems that it’s this part but I get conflicting data as to whether it’s compatible with my wabco unit (need to find out what unit I have in the first place) Would appreciate as to whether it’s works or not. Cheers OB I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html |
18th Sep 2019 9:19am |
Dieseljock Member Since: 03 Jun 2017 Location: Inverclyde Posts: 31 |
This is what i fitted to mine.
https://rover.ebay.com/rover/0/0/0?mpre=ht...3352772873 It re-routes the wiring which usually cracks and corrodes in the shuttle valve switch pack. The td5 disco abs module is a straight swap although the pipe layout is marked differently. Still worth fitting the modified switch pack |
19th Sep 2019 8:48pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 556 |
Same shuttle valve on the Disco as Defender. Fit a new shuttle valve (around £35/40) and search on golden for Disco abs mod, I’ve done 2 Discovery’s and my Defender and they work fine 👍
Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
19th Sep 2019 10:31pm |
