Home > Technical > Part SWO500030 - Wabco ABS shuttle valve
OsloBlue
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
All since my ABS has thrown a fault I’ve been looking for a solution short of buying a new / refurbished unit
In my search I’ve come across part no SWO 500030
Now my repair guy has a disco pump and said he could cannibalise it and take the part to repair my ABS
Seems that it’s this part but I get conflicting data as to whether it’s compatible with my wabco unit (need to find out what unit I have in the first place)
Would appreciate as to whether it’s works or not.
Cheers OB I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html
Post #793758 18th Sep 2019 9:19am
Dieseljock
Scotland 2003 Defender 90 Td5 HT Zambezi Silver
This is what i fitted to mine.
https://rover.ebay.com/rover/0/0/0?mpre=ht...3352772873
It re-routes the wiring which usually cracks and corrodes in the shuttle valve switch pack. The td5 disco abs module is a straight swap although the pipe layout is marked differently. Still worth fitting the modified switch pack
Post #794105 19th Sep 2019 8:48pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Same shuttle valve on the Disco as Defender. Fit a new shuttle valve (around £35/40) and search on golden for Disco abs mod, I’ve done 2 Discovery’s and my Defender and they work fine 👍
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #794134 19th Sep 2019 10:31pm
