![]() | Home > Tdi > 200tdi Defender LT77 - downshift into 3rd is crunching |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2277 ![]() ![]() ![]() |
Duff syncro ? Does it change smoothly down if you double declutch?
Ashcrofts recommend Dextron 3 in their rebuilt LT77 boxes. TBH unless you want to pull the gearbox out and get it repaired, I'd use the brakes more and change down at sub-graunching speed HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1675 ![]() ![]() ![]() |
Did they replace the thrust washers in the hubs?
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 ![]() ![]() ![]() |
I've tried to double and triple de-clutch and it doesn't make a difference. I drive like you say, slow down to the slow speed then change to 3rd, but sometimes you need a downshift to 3rd when towing, regardless it should be working spot on after the rebuild. |
I assume they did, like I said i had it rebuilt and my instructions were I wanted 'as new'. |
Indeed it should, I agree. Looks like it's gearbox out time and back to the rebuilder.
Have you spoken to them ? Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
I have spoken but it's the hassle of it all.
In his words is he'll sort it out if I take the box to him, but that's the problem I'm not able to do that. |
I understand your frustration but unfortunately the only way to resolve the issue is to remove and return it for the remanufacturer to repair it
![]() Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
My hope was that someone would know so i could fix it myself on the weekend.
Since the baulk rings are new could it be the gear itself ? What would you say ? |
OJ Member Since: 23 Nov 2018 Location: North of Edinburgh Posts: 121 ![]() ![]() ![]() |
Agree with Mo ![]() |
There is no magic fix unfortunately. You’ll have to remove the box, unless the shifter is incorrectly adjusted.
Might be worth talking to Ashcroft’s I always find them very helpful. |
