Home > Tdi > 200tdi Defender LT77 - downshift into 3rd is crunching
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
I was wondering if anyone who knows these boxes could help me.
The story is that I got the LT77 gearbox rebuilt to be 'as new' during rebuilding the defender, and as such all the bearings and baulk rings etc should be new.
Since getting the car working on the road it's been crunching into 3rd on the downshift from 4th. Always at speeds about 40mph or higher, nothing drastic, just regular downshifting into 3rd when slowing down.
I kinda prayed it would bed in and go away but it's not got any better over the last 5k miles Sad
At first I had the prescribed ATF Dextron II in it, tried Redline MTF but it's still the same. Bias springs are perfect and the rest of the gear changes are spot on. Up-shifting into 3rd is faultless, which is why I'm confused.
Since the baulk rings are new along with everything else, does anyone know why this could be so I can perhaps fix it myself ?? If that's even possible with simple tools.
Hopefully this gives the full details, if not let me know
Dylan
Post #793521 17th Sep 2019 8:57am
Mo Murphy
Duff syncro ? Does it change smoothly down if you double declutch?
Ashcrofts recommend Dextron 3 in their rebuilt LT77 boxes.
TBH unless you want to pull the gearbox out and get it repaired, I'd use the brakes more and change down at sub-graunching speed
HTH
50 Shades of Pennine Grey
Post #793597 17th Sep 2019 1:18pm
NickMc
Did they replace the thrust washers in the hubs?
Post #793722 17th Sep 2019 11:34pm
windy81
HTH
Mo
I've tried to double and triple de-clutch and it doesn't make a difference.
I drive like you say, slow down to the slow speed then change to 3rd, but sometimes you need a downshift to 3rd when towing, regardless it should be working spot on after the rebuild.
Post #793777 18th Sep 2019 11:00am
windy81
I assume they did, like I said i had it rebuilt and my instructions were I wanted 'as new'.
Post #793778 18th Sep 2019 11:01am
Mo Murphy
Indeed it should, I agree. Looks like it's gearbox out time and back to the rebuilder.
Have you spoken to them ?
Post #793791 18th Sep 2019 12:23pm
windy81
I have spoken but it's the hassle of it all.
In his words is he'll sort it out if I take the box to him, but that's the problem I'm not able to do that.
Post #793799 18th Sep 2019 1:20pm
Mo Murphy
I understand your frustration but unfortunately the only way to resolve the issue is to remove and return it for the remanufacturer to repair it Crying or Very sad
Post #793800 18th Sep 2019 1:31pm
windy81
My hope was that someone would know so i could fix it myself on the weekend.
Since the baulk rings are new could it be the gear itself ? What would you say ?
Post #793830 18th Sep 2019 5:40pm
OJ
Scotland 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Mo
Agree with Mo Sad
Post #794283 21st Sep 2019 12:52am
NickMc
There is no magic fix unfortunately. You’ll have to remove the box, unless the shifter is incorrectly adjusted.
Might be worth talking to Ashcroft’s I always find them very helpful.
Post #794404 21st Sep 2019 10:18pm
