![]() | Home > Stolen > Stolen - Green Defender Puma 2.4 |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2314 ![]() ![]() ![]() |
Oslo, this weakness does not specifically relate to the Optimill swivel, it applies to any steering lock by disconnecting the steering column/steering box from the steering arms by simply undoing a single nut at the front underside of the vehicle and steering the vehicle manually using the road wheels I am not a vehicle thief, but do have a basic mechanical knowledge which is all these people need to conjure workarounds > 110 XS Double Cab |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825 ![]() ![]() ![]() |
Keep it parked in the gear you entered. I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
Smash the window and stick it in neutral... No I shouldn't give the thieves ideas. > 110 XS Double Cab
Is this a wind up? I'm on IG: https://www.instagram.com/osloblue42/
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 747 ![]() ![]() ![]() |
What if it a model with armoured glass? |
Rkcorry Member Since: 23 Jan 2017 Location: Northern Ireland Posts: 226 ![]() |
Does anybody bother with a good old fashion wheel clamp
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17559 ![]() ![]() ![]() |
Oh, yes. A good quality local authority grade wheel clamp is still a very effective deterrent (and also useful if you need to park illegally)!
