Home > Stolen > Stolen - Green Defender Puma 2.4
Page 4 of 4 <1234
hank
Dobby wrote:
The weak point is also the steering linkage. Your £300 shiny boss is easily overcome by removing a split pin and a castellated nut.
Oslo, this weakness does not specifically relate to the Optimill swivel, it applies to any steering lock by disconnecting the steering column/steering box from the steering arms by simply undoing a single nut at the front underside of the vehicle and steering the vehicle manually using the road wheels
I am not a vehicle thief, but do have a basic mechanical knowledge which is all these people need to conjure workarounds > 110 XS Double Cab
Post #793493 17th Sep 2019 7:42am
OsloBlue
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Keep it parked in the gear you entered. I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html
Post #793516 17th Sep 2019 8:43am
hank
Smash the window and stick it in neutral... No I shouldn't give the thieves ideas. > 110 XS Double Cab
Post #793523 17th Sep 2019 9:07am
OsloBlue
Is this a wind up? I'm on IG: https://www.instagram.com/osloblue42/
Post #793527 17th Sep 2019 9:21am
There is of course a 30 second operation that will get around both the handbrake and it being left in gear and which won't set off the alarm and doesn't require access into the vehicle.
I can't say what it is though in case the one tealeaf who doesn't already know reads this! Thumbs Up
Post #793619 17th Sep 2019 2:27pm
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
What if it a model with armoured glass?
Post #793635 17th Sep 2019 4:46pm
Rkcorry
Does anybody bother with a good old fashion wheel clamp Very Happy
Post #794184 20th Sep 2019 2:01pm
Oh, yes. A good quality local authority grade wheel clamp is still a very effective deterrent (and also useful if you need to park illegally)!
Post #794196 20th Sep 2019 4:06pm
Page 4 of 4 <1234
