![]() | Home > In Car Electronics > DAB Reception lost when ignition is on |
USB mobile phone charger ? most are switch mode power supply will cores lost radio reception then power up
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 917 ![]() ![]() ![]() |
Is it possible you’re getting interference from something that only comes on with the ignition? Something along the lines of LED daytime running lights Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
dashcam?
cold Member Since: 15 Dec 2018 Location: Yorkshire Posts: 123 ![]() |
many thanks for the replies - DRL’s may be an option, though they do come on in second ignition position (glow plug) and radio works but will do a full test at the weekend - unfortunately no dash cam or USB chargers though. If its not the unit then it must be electrical interference and lights are my best bet.
It was DRL’s, a couple of RF chokes on the DRL loom and we have a signal - thanks all!
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4801 ![]() ![]() ![]() |
Glad you got that sorted, hope your other repair is a quick one too. 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
Thank you, the joy of Defender ownership, one minute you are stressing over something as small as static as you cant get great DAB reception driving to work....then problem solved you cant drive to work
Brilliant summary and Im sure we have all felt exactly that
![]() 2008 SVX 90 2000 XS TD5 90 |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2230 ![]() ![]() ![]() |
and "stripes"..........you can't forget stripes..........
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 702 ![]() ![]() ![]() |
I've had this issue ever since I've had DRLs. When you say RF Chokes what did you use and where?
Thanks 2008 Defender 110 XS SW - M57N2 / 6HP28X |
Ferrite Ring Cores - you clip them over the cable as close to the ‘source’ in this case DRL as you can - link to Amazon below - hope that helps
https://www.amazon.co.uk/QPOWER-Ferrite-Su...&psc=1 |
Great .. thanks 2008 Defender 110 XS SW - M57N2 / 6HP28X
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20751 ![]() ![]() |
Is there anywhere you SHOULDN'T use the Ferrite chokes? WeWillWin🇬🇧🇺🇸
peanutbob Member Since: 12 Feb 2009 Location: UK Posts: 324 ![]() ![]() |
Resurrecting this thread…I have just collected a 12 plate puma with a Pioneer dab radio. As soon as the headlights are used the signal disappears . The aerial is unfortunately a stick on glass affair, which is not helped as the front screen is heated. But with headlights off it works ok, bar the ott complexity of the Pio unit.
I’m assuming that the cure will be ferrite cores close to the unknown make led headlights? Thanks |
